Need Assistance!
Old Jul 19, 2007 | 05:29 PM
MyLadyZ's Avatar
MyLadyZ
Default Need Assistance!
http://www.autoanything.com/suspensi...0A2069079.aspx
Im planning on buying 5mm wheel spacers on this site for $60.95 but im not shure if its for each or all? Anybody know ? if its $60.95 for each? or for a package of 4? or 2?
Thanx!
Old Jul 19, 2007 | 06:32 PM
hndumafia's Avatar
hndumafia
it for a pair.
may i recommend that you buy the spacers from a board sponsor. they can take care of all your questions for you too then.
Old Jul 19, 2007 | 09:14 PM
MyLadyZ's Avatar
MyLadyZ
yeh that be great but all 4 wheels must be spaced right? or only the rear ?
Old Jul 19, 2007 | 09:22 PM
OffsetZ33's Avatar
OffsetZ33
You are spacing out stock wheels? You are going to want to go more than 5mm if that is the case.
Old Jul 19, 2007 | 09:36 PM
MyLadyZ's Avatar
MyLadyZ
no im not spacing out stock wheels and yeh i was thinking 5mm but i need all 4 wheels spaced?
Old Jul 19, 2007 | 09:37 PM
hndumafia's Avatar
hndumafia
well what are the sizes and offsets and tire sizes that you are using?
Old Jul 19, 2007 | 09:39 PM
MyLadyZ's Avatar
MyLadyZ
19x9.5 +22 in the front and 19x10.5 +22 in the rear
Old Jul 19, 2007 | 09:44 PM
OffsetZ33's Avatar
OffsetZ33
It just depends on the look you want, and how much neg. camber you want to run. Also, tire size is important to know. Im running 9.5 +12 w/3mm spacer (+9) and 10.5 +12 no spacer although I have room to put one on. So I would say you could run anywhere up to a 15mm spacer depending on how aggressive you want to go (or even more if you really wanna go crazy). 5mm should be a reasonable space out depending on tire size. If you have wide tires, you may not be able to get away with too much though.
Old Jul 19, 2007 | 09:53 PM
MyLadyZ's Avatar
MyLadyZ
oh ok thanx alot but again spacing all 4 wheels isnt necessary? it just depends on how i want it to look right? wat do u suggest?
Old Jul 19, 2007 | 10:05 PM
OffsetZ33's Avatar
OffsetZ33
No it is not neccessary to do all 4 wheels, but you may as well if you have the room. Again it depends also on what size tires you are running. I have 265s on the front so that makes it harder for me to run the lower offsets. You can get away with lower offsets with smaller tires easier.
If you want a no hassle solution then I would suggest the 5mm front and rear. If you dont have super big tires then you could get away with more. Are your fenders rolled?
350z_z33.
Jul 3, 2017 04:01 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
