Another TPMS Victim
Old Jul 26, 2007 | 01:23 PM
PPW_07_Z's Avatar
PPW_07_Z
Default Another TPMS Victim
Well, I've officially had the car for 5 days now and I've manged to put around 300 miles on it - and today I get the TPMS warning light flashing and then it stays on - looks like a malfunction already!!
I hope the dealer takes care of it and they better not charge me for this!!!
Anybody else have this problem very early on with your car?
-'07 Enthusiast
Old Jul 26, 2007 | 02:41 PM
CLETUS's Avatar
CLETUS
before you get all bent out of shape......what is the tire pressure (cold) of all four tires? TPMS sytems have thresholds both above and below a certain psi. if the high threshold is say 43 psi and you tires are 40 psi cold then when you drive and they heat up, this will set of a warning lamp. the car is still under warranty, just calm down and let the dealer fix it. also you could have a tire that is low.....check the pressure on the pod on the dash.
MDaniel22's Avatar
MDaniel22
It came on in my 06 a few days after I took it home. If pressure in tires is ok take it back and they will reset the TPMS.
Old Jul 26, 2007 | 03:37 PM
stylett9's Avatar
stylett9
unfortunately Nissan didn't give us 07 owners the luxary of the monitor system in the POD. We only get the warning light....pretty lame. i was disapointed.
Possibly you have a nail in one tire and it really is low?
Old Jul 26, 2007 | 03:50 PM
DavesZ#3's Avatar
DavesZ#3
Victim? I didn't know that the TPMS was known for victimizing Z owners.
I assume you read your owners manual and know what the TPMS warning light is all about. If so, you would have checked the pressure in the tires first to see if they are all good.
Old Jul 26, 2007 | 06:59 PM
PPW_07_Z's Avatar
PPW_07_Z
Hey guys, thanks for the comments! Yeah, I've checked out the owners manual and also checked the tire pressure today. I had already read about the cars being shipped with the tire pressure higher than the recommended psi, so I changed the tire pressure to 35 first thing. I rechecked them today when the light was on and everything seemed fine also - so it blows my mind why the light is giving me the "quick flash, then staying solid" which means "the tmps system is malfunctioning" according to the manual - then later today it went off and now tonight it's back to "quick flash for a minute, then solid"...maybe one of the sensors is bad and is only sending a signal half of the time?
Oh and for the "victimizing" part in the title - I had noticed a few other threads about the problem, so I was just venting
Old Jul 26, 2007 | 07:30 PM
TheProfessional's Avatar
TheProfessional
my 2006 TPMS light came on after 300 miles, I took it back to the dealer and they reset the code.... no big whoop.
Old Jul 26, 2007 | 08:49 PM
evolved326's Avatar
evolved326
Mine went off too. Turns out I had a nail in the passenger side rear tire. $20 to fix.
Old Jul 26, 2007 | 08:55 PM
mikez97's Avatar
mikez97
well mine did something almost the same as yours but i pumped them up to 38psi and the llgiht was still on but wat happens you set it then take it for a quick drive then see if the light will go out
Old Aug 3, 2007 | 07:49 AM
240Zplus110's Avatar
240Zplus110
My 06 has had the TPMS reset two times, a new sensor installed once and again reset once since the new sensor --- the dealer is clueless as to what the issue could be.
Anyone else had this problem?? any sucess in getting it fixed??
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
