Will 245/40/18 fit on my 350Z?
Old Aug 4, 2007 | 06:59 AM
Dissenter's Avatar
Dissenter
I have an 04 Track Model and just replaced the tires.
Front 245/40/18
Rear 275/40/18
I could have gone with a lower profile in the front (35), but I decided to keep the 40.
The rear tires look awesome with that 275 width.
Old Aug 4, 2007 | 10:41 AM
rkd350z's Avatar
rkd350z
Front 245/40/18
Rear 275/40/18
You know wassup! haha
Old Aug 24, 2020 | 03:29 PM
Justin Ortega's Avatar
Justin Ortega
Default I jus got some esr 18 inch 9.5 width at positive 22 offset
I wanted to know if 245 35 or 40 would be best for this i havent staggered anything running square rims I jus ordered waiting for shipping. anyone can let a hand to a fellow over here. there's no vdc fuse in the vdc box inside the fusebox by battery. wondering if it will be all good with the 245 35 or 40 r 18. if not any feedback would be wonderful.
Old Aug 24, 2020 | 03:32 PM
travlee's Avatar
travlee
Master
13 year dead thread, What wheel specs? Most run a 255/40 275/40 combo
Unless you want that dumb stretch look
Old Aug 24, 2020 | 05:23 PM
Justin Ortega
I have 18s by 9.5 width and+22 offset on back on front. trying to run a square setup
Old Aug 24, 2020 | 06:20 PM
travlee's Avatar
travlee
Master
Why square?
Old Aug 24, 2020 | 06:59 PM
Justin Ortega
Default 8
I want to be able to spend as less on tires as possible
Old Aug 26, 2020 | 04:40 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Why not just get stock sized tires, 225/45 front 245/45 rear... Its not like your wheels are super wide, they will be cheaper and fit fine, and no worries about traction control...
But yeah 245/40/18 fit fine in the front, that's what I have on 9.5 inch wheels.
Old Aug 26, 2020 | 08:33 PM
Justin Ortega
thats on front and rear?
Old Dec 2, 2020 | 04:18 PM
Fxckbrian's Avatar
Fxckbrian
Originally Posted by veloceZ
Excellent, I'll check tonight when I get home. I rode the motorcycle to work since the tires are shockingly bad. Which, actually... brings me to another topic, perhaps for another thread. All four tires have gone bald on the inside 3" of the tread. There's still TONS of tread left on the rest of the tire. I am guessing the previous owner set it up that way for cornering?
BTW, is there any way to infer the wheel width from the tire size currently on the wheel (e.g., 245). I am guessing they are 8.0", but I will have to check.
previous owner was drifting and you probably need an alignment. I drift my z and I need alignment. The outcome is inner tire wear.
Old Dec 2, 2020 | 04:37 PM
travlee's Avatar
travlee
Master
You responded to a thread from 2007
MicVelo's Avatar
350Z/370Z Tech Moderator
veloceZ has not been on this forum since this thread was written some 13 years ago. I'm sure he'd appreciate the answer though.
Old Dec 2, 2020 | 05:50 PM
terrasmak's Avatar
245/40-18 is a common size and works ok. Its a perfect front, and makes a good rear tire for a square setup
_koubie_
Sep 20, 2015 06:34 PM
