the difference...
Old Jul 30, 2007 | 11:21 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
Default the difference betwwen rim lips
noobie question. whats the difference between:
machine lip
chrome lip
polished lip
on rims they all look the same to me.
Old Jul 30, 2007 | 11:23 PM
Nexx's Avatar
Nexx
machine lip
chrome lip
polished lip
machine = polished, i think
chrome lip = bling and people will hate on you because its chrome even though it looks just like its been polished only cleaner.
Old Jul 30, 2007 | 11:35 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
machine lip - The metal is smooth but left in the original metal finish without any coating
chrome lip - The wheel or parts are actually dipped or plated in chrome. Soap and water are generally the way to clean these wheels. No polish required if the chroming was done right
polished lip - The wheel or lip has been polished to a bright mirror finish almost like chrome but requires repolishing over time to keep the finish.
Old Jul 30, 2007 | 11:39 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
so most or all volks with lip comes in chrome right. can you wash polish with other then soap and water?
Old Jul 30, 2007 | 11:41 PM
JDMFairladyZ33
No Volks are not chromed. They are most likely polished with a clear coat. It is because of the coating you should not use any type of polishing agent. Volks kind of stray from the 3 examples given.
When cheap chroming fails, they will flake and chip in pieces. When the volks clear coat fails you'll see water spots and stripping on the finish almost like plastic peeling.
Old Jul 31, 2007 | 12:12 AM
redlude97's Avatar
redlude97
Those are only partially correct.
Machined lip: "polished" using a lathe(machine) to cut the surface until it is relatively smooth with a shiny finish. This is the finish on alot of the cheaper 1piece wheels such as axis. Volk LE series wheels are also finished using this technique
Polished lip: Lip is first machined to a smooth and semishiny finish, and then polished to a mirror like shine with metal polishers etc.
The type of lip is usually not associated with the particular finish that is applied. Both machined and polished lips can be left bare or coated. Machined lips are usually clearcoated with paint/powdercoat, while polished lips are finished with anodizing due to the supersmooth surface resulting in poor adhesion of paint/powdercoat.
Old Jul 31, 2007 | 12:29 AM
JDMFairladyZ33
Well my comments on machine finish is more about the wheel and not the lip. You are correct in saying that machine finished lips can have a clear coat on them. I have seen many cheaper or discount wheels, especially for trucks, in which the machined finishes of the wheel are not shinny and left in the more natural metal finish without a coating. American Racing is a good example of this.
Old Jul 31, 2007 | 12:50 AM
myZter's Avatar
myZter
PREMIER MEM.FTW
so the LE37ts can be washed anyway because it doesnt have any coating on it?
Old Jul 31, 2007 | 01:39 PM
Nexx's Avatar
Nexx
they have a clear. use only clean microfiber towels and simple soap and water. do not use a lot of down force on the lips. use wheel wax for added protection.
Old Jul 31, 2007 | 02:02 PM
DHCrocks's Avatar
DHCrocks
if you look closely at a machined finish it's not reflective like a mirror but has a very fine texture/grain to it. of the three it's the least reflective.
a polished finish is perfectly clear and reflective it looks like a mirror.
a chrome finish is reflective like a mirror but often times you can see a wavy surface, it's not very noticeable but it's there, it's because it's actually a coating on the surface and is dipped in to the solution. Chrome has the deepest shine it's hard to explain but it just looks deeper.
__jb
Mar 21, 2009 03:50 PM
QdotJ
Southern California
24
Mar 10, 2008 07:14 PM
QdotJ
Mar 7, 2008 08:16 PM
Kabs
Mar 20, 2006 10:25 AM
Jason@Performance
Jan 18, 2005 03:31 PM
