tpms on 07 Z
I just installed my 19inch rays wheels yesterday and the (!) on the the dash came on. All 4 tires were low on pressure and I inflated it to proper air pressure but the light is still on. My previous 05 had the same problem when I installed 19inch wheels but came off, is there way to disable that warning light?
Did you move the TPMS valve stems into the new wheels? They must go into the same wheel they came out of ex: left front to left front
If you did change them then they probably don't work with your wheels. The TPMS valves must be at a 45 degree angle or something like that.
One last thing, read the stickies and you will find everything you want to know on TPMS.
Originally Posted by Rexy7
tpms will not mount on aftermarket rims, im going to try to disconnect and connect the battery, thanks for the help.
Originally Posted by Tac-M
Try to put them all inside the spare. Let us know if this works. I think I saw someone do this, but I can't find the results....
https://my350z.com/forum/showpost.ph...9&postcount=44
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
damnt nissan dealerships
