Rays Lug Nuts Q
Old Aug 5, 2007 | 10:26 PM
Amiricanmade's Avatar
Amiricanmade
Default Rays Lug Nuts Q
Ok, so i picked up a set of the Rays Long Extended Lug-Nuts. I noticed that it sticks out a lil on the rear and i'm not diggin that (i got the time attack's 19x9.5/10.5 +22 offset). I love how the front looks but the rear lugs are sticking out a lil too much. I plan on getting a set of eighter 5 or 10mm spacers for the rear. My Q is that if i get the 5, 10mm spacers woudl i be ok with my stock bolts or will i need new ones? Now...if i'm ok with the stocks does anyone konw if that will help bring out the wheels a lil and also help bring in the lug nuts?...and if not does anyone konw if i get new threads if the lug-nuts will still look the same or not? Thanks guys
Old Aug 5, 2007 | 10:31 PM
350Z84's Avatar
350Z84
I think if you get the 5mm spacers you do not need extended lugs, but would make your lug nuts stick further out. If you go with 10mm or thicker you will need extended lugs if it doesn't already come with extended lugs. Depending how much more the lugs come out would change how much further in or out your lug nuts would be.
Old Aug 6, 2007 | 08:21 AM
Volk350Z's Avatar
Volk350Z
Master
with or without spacer the lugs will sit the same, cause the spacer goes on the back of the wheels not where the lugs sit..
I like the extended, it give the car alot more aggressive look...
Old Aug 6, 2007 | 01:12 PM
Amiricanmade
hmm i see, Brian do you know if the 19x10.5 +12 sit the same as the +22's as far as the lug's go?
Old Aug 6, 2007 | 03:22 PM
Volk350Z's Avatar
Volk350Z
Master
if you get +12 F & R I know those have the same depth...
Old Aug 6, 2007 | 03:23 PM
yoichi's Avatar
yoichi
Extended ftw
Old Aug 7, 2007 | 03:26 PM
VIZAGE's Avatar
VIZAGE
Could you guys give me a link for these Rays lugs? Thanks.
Old Aug 7, 2007 | 05:11 PM
Volk350Z's Avatar
Volk350Z
Master
http://mynismo.com/products/?id=3974
Old Aug 7, 2007 | 08:24 PM
Amiricanmade
https://my350z.com/forum/showthread.php?t=292409
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
