Front Fender Rolling
Old Aug 11, 2007 | 09:59 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Question Front Fender Rolling
Quick basic question: Will the liner still fit if you roll the front fenders?
Yes I plan on rolling mine. I do HPDE & Auto-X events and don't want the worries of the front fenders rubbing my tires under load.
Old Aug 11, 2007 | 10:35 AM
VIZAGE's Avatar
VIZAGE
You can't roll the fronts, only the rears. If you look at the front, that's what the rear should look like after they have been properly rolled.
Old Aug 11, 2007 | 10:48 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Never heard you can't roll the front. Not home till Sept to look.
Old Aug 11, 2007 | 01:00 PM
DavesZ#3's Avatar
DavesZ#3
Yup, front's are "pre rolled" from the factory. I sure wish they had done the rears too.
Old Aug 11, 2007 | 01:39 PM
DMK's Avatar
DMK
I am guessing they didn't do the rears because those don't turn.
Old Aug 11, 2007 | 06:42 PM
drsifu's Avatar
drsifu
fronts are rolled. did you mean pull the fenders?
my rears are both rolled and slightly pulled.
Old Aug 11, 2007 | 06:46 PM
Chad68's Avatar
Chad68
Pulled? Like how far can you pull the fender? Doesn't it get distorted, with a peak in the middle of the wheel well arch?
Old Aug 11, 2007 | 06:50 PM
drsifu's Avatar
drsifu
nope. it's a real slight pull...maybe 3-5 mm. not enough to cause deformation, but enough to give you even more tire clearance.
Old Aug 11, 2007 | 07:01 PM
jcpeyton's Avatar
jcpeyton
+1 Can't roll the fronts. Take a look @ the fronts and you will see they are already folded back flat. The rears have a 3/8"/4/8" shelf that can be rolled back to accomodate wider wheels/tires.
"Pulling" is a much more complicated process than "rolling", and could result in paint cracking way up on the fenders, and could necessitate a costly repaint.
Old Aug 12, 2007 | 07:23 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
<-- I'm in Kuwait so I can't look. Thanks for the info though.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
