Can i use 17 wheel with track with brembo and vdc?
Old Aug 20, 2007 | 06:47 AM
silviakoko's Avatar
silviakoko
Default Can i use 17 wheel with track with brembo and vdc?
What is the size or brand of 17 wheels will fit track with brembo without an issue?
Old Aug 20, 2007 | 08:48 AM
Anu2g's Avatar
Anu2g
i've heard the stock 17s off earlier model Zs fit over the brembos...i'm not sure which other ones fit
Old Aug 20, 2007 | 09:10 AM
1nate7's Avatar
1nate7
Stock 17's will clear and most aftermarket wheels will clear provided you get the right offset. Enkei RPF1 and 5zigen FN01R-C are a couple of the cheaper wheels that are also lightweight.
Old Aug 20, 2007 | 08:28 PM
silviakoko's Avatar
silviakoko
mind to provide mne the right offset
Old Aug 20, 2007 | 11:26 PM
The problem is not the distance between the calliper and spokes. That's easy to figure out with offset.
The problem is the distance between the outer edge of the calliper and inner edge or the wheel. Wheel manufactures do not publish these specs. That's why 18 inch wheels are recommended with big brakes.
Old Aug 21, 2007 | 07:36 PM
1nate7's Avatar
1nate7
Do you have a particular wheel in mind? 9.5" wide with an offset around +30 works pretty well for track use.
Old Aug 22, 2007 | 11:38 AM
NoahzBurnt's Avatar
NoahzBurnt
FWIW....stock 17's will fit OEM BREMBOS....
