Lug Nuts or the BOLT
Old Aug 21, 2007 | 03:18 PM
bassholic's Avatar
bassholic
Default Lug Nuts or the BOLT
I am not sure the technical name, but i am looking for help with the BOLTS that the Lug Nuts screw on to.
Could someone please inform me the name of this/these parts b/c i need to purchase a new set up, OEM. One of the bolts is sheered so i need to replace the item(s).
Any help is appreciated!
Thanks
Old Aug 21, 2007 | 03:44 PM
bassholic's Avatar
bassholic
ok i think what i need is the wheel hub, can anyone tell me the best place to purchase from
Do i need to purchase the entire wheel hub, or would it be item 3 the wheel stud back?
Old Aug 21, 2007 | 04:02 PM
JokerDev's Avatar
JokerDev
The wheel hub is the round disc with all the wheel studs
The actual bolts are the wheel studs. Lug nuts screw onto the studs
You can replace just the studs if you need, don't need a new hub
Old Aug 21, 2007 | 04:04 PM
bassholic's Avatar
bassholic
Thank you for the help looks like i will be just doing the studs.
Obviously infiniti can do this, would you assume any shop should be able to do the work. Say, the mom and pop shop that is a little more customer service oriented
Old Aug 21, 2007 | 04:25 PM
redman333's Avatar
redman333
You can do it yourself, its not hard. I did mine in about 20 min. The studs just hammer right out. But if you don't want to, yeah any small shop will be able to do it.
Old Aug 21, 2007 | 04:39 PM
bassholic's Avatar
bassholic
^^ Thanks agian, i have found some step by steps. It just sucks that i don't have brakes and rotors to change at the same time! Guess i should order those for whenever i am ready.
Thanks for the quick help everyone
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
