18x9 all around on a sedan
Old Aug 30, 2007 | 06:05 PM
bowzer6982's Avatar
bowzer6982
Default 18x9 all around on a sedan
Looking at going 18x9 w/40mm offset for both front and rear on a 255/40/18, is it possible, or should I jsut stick to 18x8 front and 18x9 rear?
I'm currently dropped on unrevised 350z springs, but might go lower in the front.
Currently
Here's the possible wheel, some concave to it.
comparison of the concave 18x9 on left and 18x8 on right
Old Aug 31, 2007 | 08:48 AM
NA&CH's Avatar
NA&CH
I am sure you can put on the 18x9. Haven't some guys used 18-19 X10?
Chris
Old Aug 31, 2007 | 09:20 AM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
you can definately do it... i know a sedan that ran 18x9 w/ 30 offset...
looking for pix, will post when i find it.
-sd
Old Aug 31, 2007 | 09:32 AM
redlude97's Avatar
redlude97
18x9+30 will def need a roll/aggressive camber in the rear, alot of sedan guys running the OEM coupe 19's with 8.5+33 still rub in the rear without a roll
Old Aug 31, 2007 | 01:40 PM
bowzer6982's Avatar
bowzer6982
Okay, so it seems that it's safe to say that 18x9 all around w/40mm offset will work fine.
I think that would look better than staggering 18x8front and 18x9rear.
Can't wait to see how it'll look w/255/40/18 all-around.
Old Aug 31, 2007 | 05:18 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Sep 26, 2007 | 04:43 AM
wayneside's Avatar
wayneside
i think this is the one subydude was talking about...looks pimp to me!
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
May 30, 2017 03:28 PM
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
Alexreyes
Sep 30, 2015 11:30 PM
