speedo calibration question
Old Sep 1, 2007 | 09:39 AM
stein's Avatar
stein
Default speedo calibration question
Can Nissan calibrate the speedo? I'm on stockers and it's off by ~3%. When I get new tires it will be off even more.8%F & 1.2%R). Will they correct this under warranty if they can do this? Also, is the speed obtained from the front or rear or both ends of the car?
Old Sep 1, 2007 | 09:54 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
http://www.miata.net/garage/tirecalc.html
Dont know if that helps. At my chevy dealership I work @ If they have not upgraded rims or tires we will cover it under warranty
Old Sep 1, 2007 | 10:26 AM
stein's Avatar
stein
A found a much nicer calculator here
http://www.rims-n-tires.com/rt_specs.jsp
Thanks about the chevy warranty, I suspect it's a computer thing that they just need to flash or something... Anyone else have their speedo calibrated?
Old Sep 1, 2007 | 10:45 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the speedo is indexed by axle speed...so I can't see how it could be off at all
Old Sep 1, 2007 | 02:27 PM
UltraYellow350z's Avatar
UltraYellow350z
So you know if the speedo is indexed by the front or back wheels? I want to figure out what happens if you change the wheel size off the stock with different diameters for front and rear.
Old Sep 1, 2007 | 03:09 PM
Z1 Performance
Former Sponsor
unless your Z is front wheel drive, I'd say its off the back wheels
go to any of the tire calulator sites and plug in the numbers, it will show you
Old Sep 1, 2007 | 07:02 PM
UltraYellow350z
thanks for the info, it makes perfect sense!!
Old Sep 5, 2007 | 08:35 AM
stein's Avatar
stein
I emailed the dealership here and they said the following:
5MPH IS WITHIN FACTORY SPECIFICATIONS ABOVE THAT WE COULD CHANGE OUT SPEEDO AND STILL BE OFF 5MPH
So it will cost me to calibrate it or I can just deal with it. And from his reply it sounds like they just swap out speed sensors or something...??
Old Sep 5, 2007 | 08:59 AM
stein's Avatar
stein
From what I just read in the service manual, it gets the speed from the ABS actuator and electric control unit or VDC/TCS/ABS control unit. Seems you can test it for proper functionality but can not adjust it.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
