Can I clay or use polishing compond on Volk lip?
Old Sep 16, 2007 | 06:22 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default Can I clay or use polishing compond on Volk lip?
I have LE28N. I believe it has an annodized lip with clear coat...
My rear break pad wore out during a spirited drive through a mountain course and the fine metal shavings created by metal to rotor contact sat and dug into the clear coating of the lip. I tried my best to clean it up, but I can see some rusting spots.. If it was a painted surface, I would first clay it and may be use polishing compound to remove the metal shavings that dug into the clear coat layer.. but can I do this to the lip of my volk wheel?? Thanks.
Jay
Old Sep 16, 2007 | 06:45 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Originally Posted by VN_350z
just use acidic wheel cleaner. It does a better job (:-
Are you serious?? Acidic?? Isn't that going to kill the clear coat??
Old Sep 16, 2007 | 09:16 PM
SponGer's Avatar
SponGer
Do not listen to anything VN has to say.
Old Sep 16, 2007 | 09:19 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
did you read this
https://my350z.com/forum/wheels-and-tires/293892-how-to-maintain-your-rays-wheels.html
Old Sep 16, 2007 | 09:28 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Originally Posted by myZter
Yup, read it a while ago... but, it does not mention anything about how to recondition the clear coat of the wheel lip. I don't want to repolish, re-anodize or chrome the lip... As Andy mentioned in that write up, I want to treat the wheel lip just like the painted surface.. If so, claying and maybe using a very fine polishing compound, then waxing would do the trick.
Old Sep 16, 2007 | 09:30 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Thanks.. I'm not stupid to listen to that advse anyway...
BTW, VN, you are an idiot..
Old Sep 16, 2007 | 10:33 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
if you search you can find some people take out there clear coat but it hard work.
Old Sep 17, 2007 | 03:25 AM
DavesZ#3's Avatar
DavesZ#3
Use the claybar, that should remove the brake debris from the surface.
Old Sep 17, 2007 | 06:00 AM
taurran's Avatar
taurran
Claybar - Yes
Polish... I know that Mother's makes a special polish for clearcoated wheels. I have a bottle of it, and really haven't found a good use for it yet. I used it on my wheels a few times but couldn't tell if they were actually shinier or if it was all in my head.
Old Sep 17, 2007 | 06:11 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I sure hope so!! It's not just a brake pad debris, but it's fine hot metal shavings that melted into the clearcoat as they landed..
Thanks guys..
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Originally Posted by taurran
Claybar - Yes
I should definitely look into this... Thanks..
Old Sep 17, 2007 | 07:25 AM
noodleman's Avatar
noodleman
Claybar - Yes
+1, i'd clay, but stay away from any abrasive polishes to be safe.
Old Sep 17, 2007 | 03:15 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I would avoid a rubbing compound, as the lips are anodized.
Try the claybar first (a mild compound) and see how it goes. Another thing that works amazingly well is Klasse All in One - really good for removing stains from paint work, etc, so worth a shot as well - not cheap but its a terrific product.
Old Sep 18, 2007 | 07:06 PM
timmays350's Avatar
timmays350
um call me stupid but if you have LE28's how are they "rusting" just curious if I missed something.
Old Sep 18, 2007 | 07:13 PM
redlude97's Avatar
redlude97
The embedded metal from the rotors is rusting and leaving spots. It how alot of wheels get damaged
Old Sep 19, 2007 | 02:53 AM
XM 1's Avatar
how about the Meguiar´s Deep Crystal POlish??? use it or not??
Old Sep 19, 2007 | 04:53 AM
Z1 Performance
Former Sponsor
a polish is not going to remove stains, its just going to make the surface glossier.
the lips are anodized as I recall, so you're potential fixes are very limited. Try the clay, and the Klasse is worth a shot too as it has some mild abrasives. Short of that, you very well maybe looking into sanding the surface and then having them re-anodized, or, polishing them, and then having them cleared
Old Sep 19, 2007 | 08:05 AM
redlude97's Avatar
redlude97
Good advice right here. Though the deep crystal cleaner can be substituted for the Klasse AIO as both are paint preps with mainly chemical cleaners.
