Any pics with 10.5" Rears?
Old May 23, 2003 | 03:25 PM
350zlicious's Avatar
350zlicious
Default Any pics with 10.5" Rears?
I really want to run 10.5 in the rear but want to know what rim/tire/offset combo people are using. Also if any "work" that needed to be done to make it happen. Thanks in advance!
Old May 23, 2003 | 08:16 PM
N74DV's Avatar
N74DV
I've done LOTS of research regarding offsets during the past 4 weeks. I am running 9.5" wide rear +25mm with 285/35/19 now. I have an Eibach drop and I have no rubbing issues at all.
with a 10.5 wheel in the rear you'll be safe with a 35-40mm offset and 295's.
Old May 23, 2003 | 09:23 PM
350zlicious
Thanks for the reply! So a 10.5 Volk TE with 22mm offset will rub without modification? Any more experience out there?
Old May 23, 2003 | 09:27 PM
N74DV's Avatar
N74DV
I would suspect that a 10.5 with 22mm will require fender rolling.... even then it may stick out too far.
10.5 with +22 mm puts the outside edge of the wheel about 5" from the wheel mounting surface.
4.8" or so is about where the fender is.... I'd really suggest a larger offset... something in the mid to upper 30's
the 22mm offset would be fine for a 9.5" wheel.
Old May 24, 2003 | 02:54 AM
MATIX's Avatar
MATIX
You can run 10.5" in the rear with +22 offset with no rubbing as long as you roll your fender.
350Z_Al
Oct 29, 2020 07:44 PM
