tar on wheels
Old Oct 4, 2007 | 12:45 PM
kevin8086's Avatar
kevin8086
Default tar on wheels
whats the best way to remove tar from wheels? went through Yosemite and they were re graveling all the roads so my car has a ton of rocks with tar stuck to my wheels and all over the car.
Old Oct 4, 2007 | 12:59 PM
redlude97's Avatar
redlude97
Claybar or a bug/tar remover
Old Oct 4, 2007 | 01:38 PM
kevin8086's Avatar
kevin8086
the bug/tar removr wont harm the wheels?
Old Oct 4, 2007 | 01:56 PM
Carefully. Any solvent that will remove tar will remove the adhesive that secures the weights.
a. Position the wheel so that the weights are at the top.
b. Try some WD-40 and a toothbrush.
Old Oct 4, 2007 | 02:06 PM
paradigm's Avatar
paradigm
Tarminator is an excellent tar remover and available at Target and many other places. be careful when you are rubbing on the tar...after it hardens it will scratch the finish on your rims. i use latex gloves and spray the area...let it dwell for a bit...then gently pick away at the chunks. the smaller bits will desolve very quickly.
regarding the toothbrush mentioned above...watch out for the bristles...they may also scratch the finish. if the brush is old, etc it can damage the finish. i learned this the hard way on darker vehicles and cleaning polish residue away from around emblems.
Old Oct 4, 2007 | 02:13 PM
kevin8086's Avatar
kevin8086
thanks guys
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
