Anyone with Altima SE-R Rims?
Old Oct 6, 2007 | 08:56 AM
SniperHunter's Avatar
SniperHunter
Default Anyone with Altima SE-R Rims?
I can't find any older threads with SE-R rims mounted onto a Z, so I wonder if many even have it done. I like the lightweight of the SE-R rims, even though I'm not crazy about the darker color. Does anyone have a set installed on their Z? I'm thinking of making them my Spring/Summer wheel.
Pics would rock, especially if anyone's repainted them to a brighter color. =)
Old Oct 6, 2007 | 09:33 AM
Tomci08's Avatar
Tomci08
not 100% sure on this but they probably have a horrible offset and you would need to use spacers. Might have problems clearing your brembo's or bbk (if equipped with either of those). Lastly you might have to stagger the tire sizes since the se-rrims might be the same widths all the way around. Not sure if your slip light will like them if they aren't staggered right.
Old Oct 6, 2007 | 10:17 AM
SniperHunter
I'm not worried about brake clearing, they're 18s and I have a Touring with Brembos. I also think they should be fine when installed on the OEM tire size, which is what I'll be using anyways.
Old Oct 6, 2007 | 10:20 AM
Tomci08's Avatar
Tomci08
In that case just check the offsets and see how those work, like i said before, you might want to use some spacers since the se-r rims will most likely have a not so good offset.
Old Oct 6, 2007 | 10:23 AM
SniperHunter
Yeah, with a 45 offset, I'll definitely need a spacer.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
