Tyre sizing 45 front 40 rear
Hi guyz, recently i needed to have my rear tyres changed due to unrepairable puncture. I had stock 225/45/R18 front and 245/45/R18 rear, My fronts are fine so only the rear is replaced to 245/40/R18s. Does the 45 to 40 profile change the VDC in any way? the tyre shop says its fine. But after some driving I'm finding VDC kick in earlier and itz a lil annoying at times.
Btw, my fronts are still 225/45/R18 rears are currently 245/40/R18.
Should I change my fronts to 225/40/R18 to make it the same?
would that make the ride better?
all suggestion appreciated. Thanx
Definitely worth 1) Sticking to stock sizes or 2) Carefully selecting your tyre / rim sizes with an online calculator to ensure the DIAMETER of the tyre remains within 2 or 3 percent of stock.
Would the correct change out for the tires be from stock:
Front: 225/45/R18
Rear: 245/45/R18
To modified
Front: 245/40/R18
Rear: 265/40/R18
Front: 245/40/R18
Rear: 275/40/R18
Front: 225/45/R18
Rear: 245/45/R18
To modified
Front: 245/40/R18
Rear: 265/40/R18
Front: 245/40/R18
Rear: 275/40/R18
Front: 225/45/R18
Rear: 245/45/R18
To modified
Front: 245/40/R18
Rear: 265/40/R18
Front: 245/40/R18
Rear: 275/40/R18
Front: 225/45/R18
Rear: 245/45/R18
To modified
Front: 245/40/R18
Rear: 265/40/R18
Front: 245/40/R18
Rear: 275/40/R18
THanx everyone, couldnt get stock size as they werent available and i had a bad puncture at rear tyre so had to go for 40s...now i need to change the fronts to 40s too....
shouldve askd first...
so havvin 225/40/R18 front and 245/40/R18 would be ok+better?
I know what you're thinking... but trying to maintain the same percentage difference when the sizes are wrong is risky. In this case, two wrongs don't make a right.
--Spike
Originally Posted by Spike100
I wouldn't do that. With this setup, you have 4 tires all sized wrong.
--Spike
--Spike
I want to change my fronts to 245/40/18 and my rears to 275/40/18 as I have just bought a set of aftermarket rims.
Depending on the cost of shipping from NZ to Australia and visa versa I would be willing to swop my tyres with you.
or assuming your wheels up front are 8" wide you could put the 245-40-18 up front and buy some new 245-45-18 for the rear
Improved handling, no VDC/TC issues. Only 1 small flaw, it becomes TAD harder to keep the car going straight at highway speeds. But its not BAD
Maybe I misunderstood your post.
--Spike
I have same setup as you then (Eagle F1 GS-D3), maybe its the *bad* roads where I am that makes it so it doesnt track as well as stock sizes. As I said though, its not that much worse.
The staggered setup (width wise) helps keeping the car going straight and feeling this way. If you go all square width wise, the front can move around a little more in relation to the rear. I never notice this with 245’s on the front of the Z, but would be concerned going much wider. I suppose the right suspension and tuning permits a wider front, but that is past the casual driver. Nissan recommends replacing the stock springs, shocks, and sway bars when mounting wider than 225 on the front.
--Spike
