wheels from an is250
Old Nov 1, 2007 | 08:33 PM
chinny's Avatar
chinny
Default wheels from an is250
would 20" sevas s55 fit on a 350z, its 225/35/20 in the front and 275/30/20 in the back and the offset of the front rim is +25mm and the back +40mm, what do you guys think ?
Old Nov 1, 2007 | 08:35 PM
Willie's Avatar
Willie
They will fit most likely but would be sunk in, look for lower offsets.
Old Nov 1, 2007 | 08:36 PM
chinny's Avatar
chinny
keep in mind i also want to lower the car
Old Nov 1, 2007 | 09:31 PM
TacoMadre's Avatar
TacoMadre
Just buy wheels that will fit on the Z instead of trying to use those. Problem solved.
Old Nov 1, 2007 | 09:52 PM
TacoMadre's Avatar
TacoMadre
Originally Posted by dave079
Common sense such as this is often looked past.
Hahaha! True...very true
Old Nov 1, 2007 | 10:36 PM
redlude97's Avatar
redlude97
You didn't even list widths
Old Nov 2, 2007 | 04:00 AM
Don't be coming around here with common sense replies.
Old Nov 6, 2007 | 04:21 AM
chinny's Avatar
chinny
Theres a Z on the sevas website with these rims on it, i think im just gonna need some beefier tires since the Z's body is more wide.
Old Nov 6, 2007 | 06:38 AM
MR_X's Avatar
MR_X
How wide are this rims? Don't worry about the tire size and stuff. Give us the width!!!! But with that rear offset and that tire size, you might need some 25mm spacers, the tire might rub against the shock.
If you put that set up as is, you might look like this
http://photos-867.ll.facebook.com/ph...34126_5648.jpg
Old Nov 6, 2007 | 06:39 AM
06MagneticZ's Avatar
06MagneticZ
All I can say is.....
Old Nov 6, 2007 | 09:23 AM
BRYCE™'s Avatar
BRYCE™
20's....yuck
Old Nov 7, 2007 | 07:13 AM
Q45tech's Avatar
Q45tech
Toyota uses a different diameter hub centric ring than Nissan even though the lug and spacing are identical. 60 vs 66
Old Nov 7, 2007 | 07:50 AM
MR_X's Avatar
MR_X
A Dremel will fix that .
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
