Aggressive Wheels and Stretched Tires....Welcome
Old Jan 14, 2013 | 09:04 AM
  #21601
potato's Avatar
potato
Old Jan 14, 2013 | 09:34 AM
  #21602
Bmurray350z's Avatar
Bmurray350z
you should get some stealth turn signal bulbs
Old Jan 14, 2013 | 10:32 AM
  #21603
potato's Avatar
potato
you mean to replace the yellow within the headlights? or was that directed at someone else?
Old Jan 14, 2013 | 10:34 AM
  #21604
GenX350z's Avatar
GenX350z
doesnt it suck without lsd??? a lot of you that are getting stuck is cause you have base models. the reason why so many people have Z's now a days is cause base models are cheap now.
Old Jan 14, 2013 | 10:55 AM
  #21605
Bmurray350z
yes, it was directed towards you lol. it'd clean the front end up a lot imo.
Old Jan 14, 2013 | 01:13 PM
  #21606
potato's Avatar
potato
i concur after looking it up
Old Jan 14, 2013 | 09:03 PM
  #21607
datsunHEAD's Avatar
datsunHEAD
more pics rouse pleaseeeee
Old Jan 14, 2013 | 10:41 PM
  #21608
th3easylife's Avatar
th3easylife
Hey guys, I was wondering if you guys could tell me whether or not 19x10 +10 255/35 and 19x12 +6 285/35 would fit.... Btw my z has around a 2 inch or so drop. I know ill need a fender roll but around how much camber should I run and also would I need a fender pull?
Old Jan 15, 2013 | 01:23 AM
  #21609
TehkMob's Avatar
TehkMob
that drop wont fit the wheels... better go lower or change you wheel setup
Old Jan 15, 2013 | 03:40 AM
  #21610
th3easylife
So if I go lower I can run the setup?
Old Jan 16, 2013 | 07:05 AM
  #21611
TehkMob's Avatar
TehkMob
Yes, its a easy setup to run, and with a +6 you can prolly get a 295 on the rear, but pretty common is 265/275 35 depending on brand. But fr it to look right, all wheel gap must be eliminated because you WILL have to run a -1.5 to -2.5 camber. and it would look funny with wheel gap. 2" isnt enough to eliminate wheel gap. look for something 10.5 +15 range, with that drop and s alignment, it should fit flush. Keep in mind this is the "stance" thread, so any setup you see in here has at LEAST a 3" drop
Old Jan 16, 2013 | 02:47 PM
  #21612
z33allme's Avatar
z33allme
car is almost back on track. A few more things needed then leaving it as is and moving onto something else.
Old Jan 17, 2013 | 05:59 AM
  #21613
TehkMob's Avatar
TehkMob
random update of the year!! Whats the car look like these days?
Old Jan 17, 2013 | 09:53 AM
  #21614
potato's Avatar
potato
Old Jan 17, 2013 | 10:00 AM
  #21615
datsunHEAD's Avatar
datsunHEAD
hey potato want to sell me your car : p
Old Jan 17, 2013 | 11:17 AM
  #21616
potato's Avatar
potato
if the price is right
Old Jan 17, 2013 | 12:27 PM
  #21617
JaE35z's Avatar
JaE35z
sick
Old Jan 17, 2013 | 04:35 PM
  #21618
sofa king's Avatar
sofa king
that color is so sick
Old Jan 17, 2013 | 05:10 PM
  #21619
solidsnake's Avatar
solidsnake
potato thats the stock spoiler right? stillen roof wing?
Old Jan 18, 2013 | 05:43 AM
  #21620
DCJodon's Avatar
DCJodon
With all that fender work you did, shoulda shaved and frame mounted the antenna!
