Aggressive Wheels and Stretched Tires....Welcome
racebreed350z!!!! Omg!!!! Please do this setup!!!! Please please please.
Finally got rid of the Nismo rep lip for a legit Veilside V1... Wheel rebuild coming after Staggered fall next month.
Attachment 356426
Attachment 356426
Guys, on Weds site they mention "Height of Hub Clearance (mm)" for the different disk options:
http://kranze.jp/english/bazreia.html
Is that the distance from the inside of a wheel spoke to the hub's mounting surface? Basically how far the caliper sticks out from the mounting surface of the brake rotor then add a couple mm of clearance?
I've read through this thread multiple times but I can't find exactly what I'm looking for. Can you guys recommend some tires for my semi-aggresive wheels? I have a set of 18x10.5 +15 ES1's square. I daily drive my car, no drifting or racing. I was thinking either 255/35 all around or 235/40 all around. What would be a good set-up with a bit of stretch but still be practical. BTW I plan to eventuallly lower it on coilovers with rolled fenders no pull.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
http://i651.photobucket.com/albums/u...m3/stretch.jpg
http://i651.photobucket.com/albums/u...3/stretch4.jpg
http://i221.photobucket.com/albums/d...s/fec27926.jpg
http://i23.photobucket.com/albums/b3...732a216b21.jpg
http://i221.photobucket.com/albums/d...s/f5c1a935.jpg
http://i11.photobucket.com/albums/a1...2-28-09015.jpg
235/40s would be good if you arent going too low. They'll be a little stretched, but not too much. It varies a little depending on the tire you go with. I would also recommend at least a 15mm spacer for the rear, otherwise, your fronts will poke out more and you'll have an fwd stagger :/ Here are some pictures I found on different forums of this setup. You'll notice that the stretch varies a little since they're different brands. Good luck!
haven't been on here since i sold my Z. i miss this community. everyone in the vip scene is all **** and ****. ive been working on the M since i sold it but i recently picked up another Z so i should be back on here more often. well heres a couple pictures of my vip platform.
Use marble instead of wood floors like everyone else. be ORIGINAL!
Not aggressive at all for the rear, that's standard aftermarket setup. You can run 285/35s and have room to spare. Look on the Enkei thread and more than half the wheels there are 18x10.5 +15.
Do you guys get this much hate too? haha
<a href="http://www.flickr.com/photos/88854602@N08/10198163796/" title="2013-10-10 17.43.32 by brandonsbryant, on Flickr"><img src="http://farm6.staticflickr.com/5514/10198163796_3c67760115_b.jpg" width="720" height="720" alt="2013-10-10 17.43.32"></a>
