Aggressive Wheels and Stretched Tires....Welcome
Old May 7, 2009 | 09:21 PM
  #2481
Royal_T's Avatar
Royal_T
Cyan,
Glad you worked them out, but yea 265's would work a whole lot better.
Oh and yea it looks funny without the spacers.
And you did not answer my question are you on bags? Just cause in some pics your rear sat lower then others, just was wondering.
Old May 8, 2009 | 06:21 AM
  #2482
lafingas's Avatar
lafingas
alrite guys....need your opinions on hear:
20x10.5 -5(F) 20x10.5 -15(R) wrapped with Toyos Proxes 265/30/20 all around
Will it fit? I will probably need a fender roll? Do I need camber work? If I do then I prob wont purchase them. I drive daily so I dont want to be rolling around with -5' camber. I have stock suspension right now, I know I'll get coilovers soon. I can get a real good deal on these so I am heavily considering the buy.
Is anybody running the same setup? If so what did you do to make it fit? Pics and Replies are greatly appreciated.
Old May 8, 2009 | 06:30 AM
  #2483
nosurf2day's Avatar
nosurf2day
Originally Posted by cyan
I was running the same 275s at +18 that I'm running at -7.
I am curious, what do you mean by -7? I am running the standard setup **STOCK** which sucks. I am getting ready to get some new rims next week. Depending on how it looks via the offset I will be deciding as to what spacers I will run if at all.
-7?
Old May 8, 2009 | 09:33 AM
  #2484
BarefootRacer's Avatar
BarefootRacer
The rear you can fit with a fender rool, slight pull and a pretty decent amount of negative camber. The front on the other hand could be done but i wouldnt suggest it if you wanna drive it alot. With that fitment you will have to pull the front fenders and run close to if not more than -3 degrees camber. Which wont be very ideal for a car you plan to drive very much. Change the front to something like a 9.5 -5 to -10 at the most or a 10.5 +5 to +10 at the most. Good luck!!
Old May 8, 2009 | 10:17 AM
  #2485
cyan's Avatar
cyan
Originally Posted by Royal_T
Cyan,
No, I'm on A'PEXi N1 coilovers. some of the pics are from a few weeks ago. I just dropped it some more last week before I took it in for the alignment. Also, the one pic where its really low (the one where I'm in the car) is because it was taken while I was in the middle of a 25mph slide and all the weight was on the right rear corner.
-7?
-7 is the offset of the wheel with the spacer installed on it.
Take the spacer off the wheel and the offset changes to +18. (It's a 25mm spacer: +18-25= -7).
Old May 8, 2009 | 12:18 PM
  #2486
fart_canon's Avatar
fart_canon
^ how about a 15mm spacer instead of the 25mm? I know the stance looks killer but what is the point if you can't enjoy your Z?
Old May 8, 2009 | 01:20 PM
  #2487
nosurf2day's Avatar
nosurf2day
Ahh okay so the more positive the offset is the further in the well the rim is. The less the offset and the further out the rim is in the well?
Stock Rim offset is?
My current rim offset is 15mm fronts and 25mm rears. They still need to come out more in my opinion.
Old May 8, 2009 | 03:48 PM
  #2488
BarefootRacer
10.5 0 offset with 265/35. Prolly about to get 20mm spacers for a -5 offset.
Old May 8, 2009 | 03:49 PM
  #2489
Ruined Z's Avatar
Ruined Z
IIRC, it is around +30 in front and +2 or 3 more in the back.
Question for everyone here:
I bought a set of Work VS-XX. 19x10 -4 and 19x11 +0.
What size tires would you guys recommend? 245 in front and 265 in back?
I don't mind a slight pull in the back and they're already rolled.
Old May 8, 2009 | 07:41 PM
  #2490
nosurf2day's Avatar
nosurf2day
I keep hearing people say they are going to pull their fenders. How are you guys doing this. Is this something your taking to a shop or is this something your doing yourself. The starter of this thread obviously went to a shop for that but a slight pull how would you accomplish this?
Old May 8, 2009 | 08:28 PM
  #2491
nosurf2day's Avatar
nosurf2day
Does anyone have any pics of what 225 on 9J rims looks like? I found what 245's would look like on 10.5J Straight hawtness! I just dont know if 225's would give me the same look. I know that my 245's dont.
Old May 9, 2009 | 08:06 AM
  #2492
g35pm's Avatar
g35pm
You could pull yourself or have a shop do it. I've seen people do it by hand or use the fender roller to do it.
Old May 9, 2009 | 08:27 AM
  #2493
07rdsterGT's Avatar
07rdsterGT
+18 is not aggressive at all. Here is a picture attached for proof of how silly +18s looked. And besides, I'm not sacrificing any tire size...I was running the same 275s at +18 that I'm running at -7.
Regardless, this debate does not belong here. If you truly feel +18 is aggressive, you are in the wrong thread.
This picture speaks volumes:
That pic of that rear wheel without the spacer doesn't look like +18. I have +19 in the rear on my car and the wheels are not tucked in at all like the picture you posted. That pic looks like +25 if not more. Also, why does is look like there is 0 camber in that pic? The wheel looks straight up and down.
Here's a quick Blackberry pic of my +26 front 19x9.5 and +19 rear 19x10.5 (RH Evolution J5 Pro) with no spacers
EDIT: I probably should go snap a pic of my car the same angle for a better comparison.
Attached Thumbnails Aggressive Wheels and Stretched Tires....Welcome-img00145-20090508-2007.jpg
Old May 9, 2009 | 08:29 AM
  #2494
BarefootRacer
^^Dudes plus 18 offset looks weak just because his car is super slammed and has a good bit of negative camber. Also the tires are smaller than most other 275's.
Old May 9, 2009 | 08:32 AM
  #2495
07rdsterGT's Avatar
07rdsterGT
Hmmm. So your saying its more of an illusion then anything.
Old May 9, 2009 | 11:51 AM
  #2496
status:one's Avatar
status:one
Any of you Dallas guys want to trade wheels for a couple weeks?
WORK Varianza T1S 19x9.5 +4 19x10.5 -2
<a href="http://s8.photobucket.com/albums/a21/Calric16n/?action=view&current=4ce90d8d.jpg" target="_blank"><img src="http://i8.photobucket.com/albums/a21/Calric16n/4ce90d8d.jpg" border="0" alt="Photobucket"></a>
Old May 9, 2009 | 01:33 PM
  #2497
BarefootRacer
Yes and plus his quarters seem to be rolled and pulled pretty good. You can gain like 10mm of space on a pretty simple fender roll and pull. The more you roll it flat the more it pulls the fender out.
Old May 9, 2009 | 02:35 PM
  #2498
Royal_T's Avatar
Royal_T
A break from the pics, here are some vids for your pleasure
<object width="400" height="225"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=2405022&amp;server=vimeo.com&amp;show_ title=0&amp;show_byline=0&amp;show_portrait=0&amp;color=ffff ff&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=2405022&amp;server=vimeo.com&amp;show_ title=0&amp;show_byline=0&amp;show_portrait=0&amp;color=ffff ff&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="225"></embed></object><p><a href="http://vimeo.com/2405022">VIP Scene Hawaii</a> from <a href="http://vimeo.com/kaimedia">KAIMEDIA</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
<object width="400" height="220"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=4109785&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=4109785&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="220"></embed></object><p><a href="http://vimeo.com/4109785">Team Top Flight X Royal Flush</a> from <a href="http://vimeo.com/user956433">Team TopFlight</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Old May 9, 2009 | 04:24 PM
  #2499
status:one's Avatar
status:one
love that S13
*drool*
Old May 9, 2009 | 05:25 PM
  #2500
07rdsterGT's Avatar
07rdsterGT
Amazing car.
«-----jealous
