Aggressive Wheels and Stretched Tires....Welcome
just got my rims in, should be on my car today around 3 central. GTS 19x10.5 all around. Ill be the first GTS owner with this setup (10.5 all around). Sitting on 255/35. Should be interesting pics up soon =)
fronts are perfect. rear might need a spacer, but nothing more then a 10mm.
still need alignment in the rear. way to much camber causing my rear to be sunk in. here are a few pics from today.
looks good. im running a square set-up as well. question for u guys, to match the stretch on my 19x10 245/35 front what should i run on my rear? i dont want to run a 245/35. so should i run a 255/35 or 265/35? rear is 19x10+5
For 1 I didn't want a staggered setup. 2 these rims are not my track wheels. And 3 they don't make that size on the GTS wheels. I love the way the fronts fit with the size I got. That's the reason I got it. I paid just as much or less then the normal price of GTS wheels from a vender on here.
yeah they do: CLICKY
same lip, same outer edge, more inner clearance.
but... whatever floats your boat
i had to special order the 19x10.5 +18 all around but i wouldnt have went with the 9.5 anyway i wanted a square setup with a big rim for more of a stretch on the size tire i got.
like i said i wont be tracking these wheels its just for show.
Ny350zG,
Man those are some lips right there.... Car is coming along nicely,, all it needs now is to kiss the ground and you my friend have money..
Jacob,
Car looks good, fronts are perfect and I do agree with you about the spacers for the rear.. I would go with a 10mm.. Nicely done
Jacob,
