Aggressive Wheels and Stretched Tires....Welcome
Old Nov 27, 2009 | 04:09 PM
  #5021
Toby-22's Avatar
Toby-22
Originally Posted by Royal_T
Damnnnn 10psi, okay I can see the rim hitting the pavement now when hitting a bump/crack. Do you have a slow leak
I dont know its too cold and dark out, ill check tomorrow. Im not sure if the crack caused the low tire pressure or not. Ill put some air tomorrow and hope for the best.
Old Nov 28, 2009 | 03:09 AM
  #5022
solidsnake's Avatar
solidsnake
<object width="400" height="225"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=7813464&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=7813464&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="225"></embed></object><p><a href="http://vimeo.com/7813464">Hella Flush III</a> from <a href="http://vimeo.com/iphilms">iPhilms</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Old Nov 28, 2009 | 04:36 AM
  #5023
10 TIL 4's Avatar
10 TIL 4
Looks good JPE...........I'm digging the contrast of those TE's with your car. Looks dope!
Old Nov 28, 2009 | 07:59 AM
  #5024
Toby-22's Avatar
Toby-22
well i woke up today and noticed both (not just the passenger side) front tires were at 5psi, i put air in em and once i hit 35psi i hear air coming out the valve stems. I had to tighten the valve caps as hard as i can in order to keep the air in (at least stop the hissing noise of air coming out). Is this normal for stretched tires? The rear with the 245 seems fine but the front cant seem to hold air in with the 235??? Again im running non staggered 10.5 all around rims.
Old Nov 28, 2009 | 08:31 AM
  #5025
shake_urzada's Avatar
shake_urzada
your tires shouldn't be leaking if installed properly. i run 235 on 10.5 and never have had a tire lose any air. i run 45 psi.
Old Nov 28, 2009 | 08:35 AM
  #5026
Toby-22's Avatar
Toby-22
so what could be the reason? It seems to be coming out the valve stems. It wasnt like this the first day the tires were mounted cuz i actually kept the caps off for a day and no problem. You guys think it was due to me hitting the crap out of the cracks? Im kinda scared to even drive around with em now
Old Nov 28, 2009 | 08:41 AM
  #5027
shake_urzada
you might want to replace the stem, not really sure, but it could be caused if its getting cold where you are the air would be denser and might have a slight leak that wouldn't be there in warmer temperatures.
Old Nov 28, 2009 | 11:18 AM
  #5028
Royal_T's Avatar
Royal_T
yea you will have to replace the valve stem.
Old Nov 28, 2009 | 01:24 PM
  #5029
dranom's Avatar
dranom
that little pin in the middle might be loose.
go to a tire shop and ask them if they can tighten it up for you
Old Nov 28, 2009 | 01:43 PM
  #5030
quakerroatmeal's Avatar
quakerroatmeal
Stretch tires run higher pressure then normal fitment?
Old Nov 28, 2009 | 04:04 PM
  #5031
BLUby_U's Avatar
BLUby_U
Tighten the valve stem core. They sell the tool anywhere. It doesn't sound like stretchin is the problem
Old Nov 28, 2009 | 04:37 PM
  #5032
JonnyB504's Avatar
JonnyB504
WHen I had a slow leak that was my problem!
Old Nov 28, 2009 | 11:27 PM
  #5033
velocityracer's Avatar
velocityracer
FINALLY!!! it took me a couple weeks, but i went through all the pages
Old Nov 29, 2009 | 07:10 AM
  #5034
Toby-22's Avatar
Toby-22
thank you, my friend had the tool and that was exactly the problem. Thanks everyone for your help!
Old Nov 29, 2009 | 06:48 PM
  #5035
dranom's Avatar
dranom
glad you got it fixed! had that problem before.
make sure to check it every week just to make sure coz mine kept on gettin loose to i got it replaced before
Old Nov 30, 2009 | 06:38 AM
  #5036
haeshik's Avatar
haeshik
bumping this thread with my homies shanes g35 on uas
http://www.youtube.com/watch?v=9Qh70nnbtNs
Old Nov 30, 2009 | 09:01 AM
  #5037
BiggieB15's Avatar
BiggieB15
great looking G ^^^^^^^^
Old Nov 30, 2009 | 10:13 AM
  #5038
fart_canon's Avatar
fart_canon
WOW! I like how that works. I can't wait to see how your Z will turn out homie.
Old Nov 30, 2009 | 10:35 AM
  #5039
Toby-22's Avatar
Toby-22
WHOA, best G ive seen
Old Nov 30, 2009 | 02:57 PM
  #5040
BiggieB15's Avatar
BiggieB15
here is my set up Ti 5's 19x9.5 +0 235/35 and 19x10.5 -5 245/35...Some quick pics
