Aggressive Wheels and Stretched Tires....Welcome
. i'm running 225/40 245/40
It really doesn't look like there's THAT much of a height difference between ridin dumped on 18's than ridin dumped on 19's..I mean if you compare pics between Royal T on 18's vs FatBoyYoshi and Starve on 19's they both look like they're ridin around the same height..
heheh word...starves car has been sitting lower though for the past 2-4 weeks haha
"heheh word...starves car has been sitting lower though for the past 2-4 weeks haha"
He needs to post some new pics of his car then
...you too Yoshi
p.s. I still want your wheels too bad I'm too freakin poor
...you too Yoshi
..p.s. I still want your wheels too bad I'm too freakin poor
Also.....anyone with stance have problems with adjusting the front shocks?
I tried to adjust my suspension in the front for the first time (Ive done the back a lot) and i can't adjust them. I loosen the bottom most collar but then when I go to turn the top collar it doesn't do anything. No matter which way I turn it. One way it just tightens up and doesnt budge and the other way it just breaks loose. Any ideas? SOme one said something about they could be seized?
Or maybe the threaded shock is bottoming out in the lower mount and its as low as it can go?
It's gotta be one or the other...
(You'll also need to unbolt the upper A-arm probably)
Pic might help too
Imma try the wd40 I was out of it at the time. But it cant be the second because I was trying to actually raise one side up a half an inch to match the other side. It wont raise or lower.
JonnyB I think all you need is a bad azz kit to help set off the wheels..
Enough talk heres a tough lookin S13 I found on hellaflush...I know most of us probably go to the site, but not enough pics bein posted
<a href="http://www.flickr.com/photos/46420692@N07/4329257470/" title="s13 by Frenz.33, on Flickr"><img src="http://farm5.static.flickr.com/4068/4329257470_d62129c155.jpg" width="500" height="375" alt="s13" /></a>
<a href="http://www.flickr.com/photos/46420692@N07/4329275136/" title="chuck_S13_2 by Frenz.33, on Flickr"><img src="http://farm3.static.flickr.com/2774/4329275136_19875e73a8.jpg" a>
Like arnt you supposed to break the bottom most collor loose then turn the top most collar to either lower or raise it?
oh nice lip by the way haha..
