Aggressive Wheels and Stretched Tires....Welcome
Old Jul 2, 2008 | 05:08 PM
  #721
type59's Avatar
type59
Originally Posted by rickyislaZy
I am running 245/35/19 and 275/30/19, 30 series in the rear allows you to drop the car more, but as far as the front wheel goes, I don't recommend you to get 235 because 245 is a better match for 275.
thats what im being told. but if you do the tire calculator thing. 245/35 is .849% to fast and 275/30 is 1.885% and 235/35 is 1.960% when compared to 225/45/18.
Old Jul 2, 2008 | 05:30 PM
  #722
35oZephyR's Avatar
35oZephyR
Originally Posted by knguyen
19X9.5 front, 19X12 rear Work VS-XX
255's up front, 295's in back.
295 Michelin PS2's ???
Only thing stretched is your wallet!
Nice ride though, diggin the setup.
Old Jul 2, 2008 | 06:11 PM
  #723
OffsetZ33's Avatar
OffsetZ33
SIN - looks great, I like the new setup
Old Jul 2, 2008 | 11:43 PM
  #724
knguyen's Avatar
knguyen
thanks man, yeah they're pilot sports
Old Jul 3, 2008 | 08:33 AM
  #725
Highstar's Avatar
Highstar
Originally Posted by Highstar
hey i have a quick question...im from g35 driver but theres not alot of gs on there who run with the aggressive/tire strecth look.
i drive a 04 g35 sedan, my wheels are 18x8+37f/18x9+45 rear planning on using 20mm spacers all around. What tire size should i use to give it that nice stretch and how much camber to use?
can someone help haaha.
Old Jul 3, 2008 | 11:07 AM
  #726
deviljon's Avatar
deviljon
well to be honest your wheels (even with a 20mm spacer) just aren't that aggressive. the stretched tire and camber helps clear the fenders but it seems like with your sizes and offsets you really wouldn't need either.
19x8 +37 for the fronts? people are fitting 2+ inches wider with single or less digit offsets
19x9 +45 even with the 20 mm spacer is not even aggressive if you were to move it to the front. I suggest doing a little research of what everyone else is running and get a new set of wheels.
just trying to be helpful!
Old Jul 3, 2008 | 11:49 AM
  #727
chromesilver6's Avatar
chromesilver6
This looks awesome!! Where did you get 12" wide vs-xx?? All you need is like a 10mm spacer on the front and youll be money ..
Old Jul 3, 2008 | 11:52 AM
  #728
type59's Avatar
type59
I wouldn't try to stretch tire with that wheel size and your car. maybe 225 all around. front won't be but the back will.
Old Jul 3, 2008 | 11:59 AM
  #729
jinsei888's Avatar
jinsei888
Originally Posted by tougeracing
MmmmMmm tasty.
clean! slammed and clean! +1 ftmwiiiiiiiiinnnnn
+ rep points...pretend rep points
Old Jul 3, 2008 | 06:13 PM
  #730
Highstar's Avatar
Highstar
so 225/40or45 all around?
Old Jul 3, 2008 | 08:15 PM
  #731
type59's Avatar
type59
do 225 and 235. same sidewall size.
Old Jul 4, 2008 | 09:26 AM
  #732
finalforce's Avatar
finalforce
Nice! You make me want to get 12" rears now. Any rubbing going on there? What's a safe offset with a wheel that wide for a slammed Z33?
Old Jul 7, 2008 | 03:53 PM
  #733
SIN3's Avatar
SIN3
thank you sir.
Old Jul 7, 2008 | 06:58 PM
  #734
StreetDReamZ33's Avatar
StreetDReamZ33
alot of nice wheel combinations!!!
+2
I like the single exhaust on the G 2 pages back, Very nice!
Old Jul 8, 2008 | 12:21 PM
  #735
SIN3's Avatar
SIN3
+2
thanks! been running it for about 2.5 years. i love it.
Old Jul 8, 2008 | 01:03 PM
  #736
terrasmak's Avatar
actually the 235 is a better match , the 245 would be the proper tire to run with the proper rear tire 275/35-19.
Old Jul 9, 2008 | 07:52 AM
  #737
type59's Avatar
type59
Old Jul 11, 2008 | 12:05 PM
  #738
SIN3's Avatar
SIN3
Originally Posted by type59
Old Jul 11, 2008 | 12:53 PM
  #739
type59's Avatar
type59
the 235 is a better match yet the proper tire is the 245?
Old Jul 15, 2008 | 10:30 PM
  #740
knguyen's Avatar
knguyen
Thanks. Yeah, I rubbed but the fenders are rolled now and no more rubbing issues. I'm only an inch lower on the rear. How low are you wanting to go?
