Aggressive Wheels and Stretched Tires....Welcome
Si3lv5er0z,
Thanks for posting, and yeah I saw those pics already. Jun takes good pics. He is the one that shoot my car awhile back...
dtsj350z,
What you have to do is let it sit in the sun so it gets hot and soft and bendable. I also add more 3mm on the side and all around.. worked perfect ..
Tribal_Visionz,
What info do you need? What I found out are few minor changes. Shorter shock body is needed and other changes here and there.. Just working out the kinks so you guys have a perfect suspension. So please be patient with me..
dtsj350z,
Tribal_Visionz,
-JP
I know someone probably asked this twice like 200 pages ago but:
What kind of front camber arms are you guys running nowadays?
I'm planning to lower some more, but need to figure out the options.
My toe/caster whatever...is chewing the shiet out of my front tires.
hey, does anyones front upper control arm hit the inner fender? i looked up some searches and saw that some people cut out the piece of fender where it hits... has anyone here done that? how would i cut that??
^^ Don't have any camber arms or toe. But I do plan on buying some.
And yeah my control arms bottom out some times, and was thinking about cutting the piece where it hits...
^ Incorrect. Theres no front camber adjustment on 350zs.
You have to have front camber arms to adjust either positive or negative.
Some camber arms are designed to add positive (SPC I think) and some are designed to add negative (Cusco). Some do both well (SPL? and Ksport)
I have Ksport ones. When I was real low I would hit my fender with them, so Id recommend cutting that spot if you get camber arms.
Then how the hell did the shop that did my alignment get my fronts back to -1.2 when they were both -1.5 before hand?
honest question since I read you cant adjust front a-arms...I also assumed you couldn't.
