Aggressive Wheels and Stretched Tires....Welcome
Old Oct 12, 2011 | 11:48 AM
  #17881
HUEY's Avatar
HUEY
Originally Posted by TehkMob
For the rear 19x11 zero to neg 8 offset will be good for running minimal camber. I'm on a 18x12 -6 with -3 camber. For the fronts you could run about the same on a 9.5 from a zero offset to a -12 offset will be fine fronts are real dependent on Tire size though. I'd opt for a 10"wide front w/225/35/19
Good luck.
thanks for the input! Since I'll be running 19" all around, wheels will be a bit harder to fit, and greater chances of fenders hitting the lip of the wheel. Is there anyone on here running 19" around the same spec, I just want to get an idea of how it'll sit, and how much camber is needed? Im going to run stretch tires, fr-225/35/19 Rr-255/35/19
that's aggressive!!!did you have to pull the fenders? you have pics?
Old Oct 12, 2011 | 11:56 AM
  #17882
vex008's Avatar
vex008
not sure how the setup would transfer / fit from a G to on a Z but its closest to the specs mentioned on rimtuck.com
http://www.rimtuck.com/search/thumbn...fsetr=0&sort=1
Old Oct 12, 2011 | 03:28 PM
  #17883
TehkMob's Avatar
TehkMob
http://s749.photobucket.com/home/Yoshi0o/index you can look through my different setups, the ordens are my most current setup. Most my specs on the front a almost the same rear specs vary from 12 +4 up to 11.5 -24.. 19x10/11 -5 with 225/35/19 and 255/35 with right tire will get best results for what you are asking for.
Old Oct 12, 2011 | 04:30 PM
  #17884
JeffJohnries's Avatar
JeffJohnries
Originally Posted by zombieskicks
Max-G I love the set up, and here's mine, going to get them painted glossy aqua/teal soon
Where can I get these center caps?!
Old Oct 12, 2011 | 06:04 PM
  #17885
phiooz's Avatar
phiooz
Old Oct 12, 2011 | 06:20 PM
  #17886
ASTIG_Z's Avatar
ASTIG_Z
what wheels are those? vsxx with a step lip?
Old Oct 12, 2011 | 06:36 PM
  #17887
datsunHEAD's Avatar
datsunHEAD
you can make those centercaps, go to the fatlace store and just buy the circle "ill"stickers and slap them on
Old Oct 12, 2011 | 07:11 PM
  #17888
phiooz's Avatar
phiooz
yessir, vs-xx with custom step lip
Old Oct 12, 2011 | 07:25 PM
  #17889
HUEY's Avatar
HUEY
sweet! seems like you pulled the rear quarter panels with the ordens, correct? I'm planning on running 19x9.5 +8, 19x11 +0 with 225/35 and 255/35..What will it take to fit them? I dont want to flare my quaters.
  #17890
.eoJ's Avatar
.eoJ
Thumbs up
looks clean phiooz
Old Oct 12, 2011 | 07:26 PM
  #17891
HUEY's Avatar
HUEY
Originally Posted by phiooz
[IMG]https://my350z.com/forum/wheels-and-tires/...
nice fitment! what size and offset are they if you dont mind sharing?
Old Oct 12, 2011 | 07:32 PM
  #17892
phiooz's Avatar
phiooz
18x10 -8 215/40
18x12 -3 255/35
Old Oct 12, 2011 | 07:45 PM
  #17893
HUEY's Avatar
HUEY
18x10 -8 215/40
18x12 -3 255/35
how much work was needed to fit them?
Old Oct 12, 2011 | 08:02 PM
  #17894
VQpoweredZ's Avatar
VQpoweredZ
Phiooz that looks soo good. Must have more pics haha.
Old Oct 12, 2011 | 08:03 PM
  #17895
phiooz's Avatar
phiooz
well before, i had a more aggressive setup 18x11.5 -23 in the rear so i had to do some pull and it ended up ****ing up my rear fenders. as you can see from the pic, i just got it out of a body shop and got everything nice a smooth. wekfest ready
Old Oct 12, 2011 | 08:28 PM
  #17896
-miltdoggie-'s Avatar
-miltdoggie-
DAMN cabron Phiooz!! Love it!
Old Oct 12, 2011 | 08:47 PM
  #17897
TehkMob's Avatar
TehkMob
Actually I brought them in for the ordens and took out camber. Previous setup was 18x11.5 -24 out back. No pull just a GOOD roll and -4.5 camber def go a little more aggressive on the front offset cuz when you go low they are going to be sunk in quite a bit.. Expect to buy 20mm spacer.
Old Oct 13, 2011 | 05:00 AM
  #17898
HUEY's Avatar
HUEY
ok i see, looks good now! did you have to do anything in the front fenders?
It'll just be different with running 19s instead of 18s on my car. So you think I should run offset in the negatives in the front to have it sit flush with the fenders?
Old Oct 13, 2011 | 08:21 AM
  #17899
Waiz's Avatar
Waiz
Black on gold is classy!
Old Oct 13, 2011 | 09:49 AM
  #17900
TehkMob's Avatar
TehkMob
Phi, you use the same body shop as cheanyoung? (spell?)
