Aggressive Wheels and Stretched Tires....Welcome
Old Jun 1, 2010 | 03:38 PM
  #9641
steroid's Avatar
steroid
Thanks for finding those pics for me!! I PM you some links!
  #9642
KingBaby's Avatar
KingBaby
Hardest Setting
toby-22 is right to lower use the cup not the upper rings...
kinda hard to explain check stances website
Old Jun 1, 2010 | 06:03 PM
  #9643
litoflow's Avatar
litoflow
Originally Posted by Toby-22
i think your lowering it the wrong way if you do have stance GR+ true style. Are you lowering it by spinning the collars down lowering the preload? Your suppose to remove the bottom half and spin the whole base of the coilover up. I did this and it didnt give me enough drop even with the preload all the way down.
First i removed the bottom half and spin the whole base down till it couldn't go no more than i loosen up the preload is this the right way? I am gonna have to check it again cause i might be doing something wrong here. I thought to lower it i should put the whole base down instead of going up, am i wrong?
This is my rear set up.
I loosen up the bottom collar and then i lowered the whole base down, then i released pressure on the springs. Is this correct? if i go up all i will be doing is raising up the rear.
Old Jun 1, 2010 | 06:23 PM
  #9644
phiooz's Avatar
phiooz
The spring should have no play except being able to spin side to side. loosen the bottom collar and spin the bottom base up.
Old Jun 1, 2010 | 06:25 PM
  #9645
Toby-22's Avatar
Toby-22
to lower it you need to spin the base where it says "Stance" up (shortening the whole coilover). The shorter the coilover the lower you will get. You can also lower it by lowering the preload (lowering the collars underneath the springs) but that isn't the suggested way of doing it. If you got them brand new the preload collars shouldn't have been touched.
Old Jun 1, 2010 | 06:52 PM
  #9646
litoflow's Avatar
litoflow
^^that is exactly what i did and just how i am lowering it. But i already maxed out the rear passenger side and i want more low :-|
Old Jun 1, 2010 | 07:28 PM
  #9647
ATX350's Avatar
ATX350
Whats up guys!?
Show some BRG love! :P
www.brgtx.com
Old Jun 1, 2010 | 07:36 PM
  #9648
litoflow's Avatar
litoflow
Eric the Web is not working..
Old Jun 1, 2010 | 07:43 PM
  #9649
ATX350's Avatar
ATX350
lol.. word? I just updated the DNS records so it may take some time to propagate.
Old Jun 1, 2010 | 07:56 PM
  #9650
theianmcdougall's Avatar
theianmcdougall
steriod
what rims/specs do you have if you dont mind me asking?
Old Jun 1, 2010 | 08:50 PM
  #9651
steroid's Avatar
steroid
18x10+0 18x11-13 works bersaglio
Old Jun 1, 2010 | 09:22 PM
  #9652
windsorvr's Avatar
windsorvr
why so much confusion about lowering coilovers...? they come with instructions on how to do it
Old Jun 1, 2010 | 10:30 PM
  #9653
steroid's Avatar
steroid
i found another pic of my carName:  527510a2.jpg
Old Jun 2, 2010 | 05:52 AM
  #9654
ryaann's Avatar
ryaann
I have the GR+ Pro true set up and my rears are fully maxed and i still wanted to go lower as well. My fronts still have plenty of room though.
Old Jun 2, 2010 | 07:07 AM
  #9655
steroid's Avatar
steroid
Ryaann. Take out the helper springs in the rear
Old Jun 2, 2010 | 08:03 AM
  #9656
CrillZ's Avatar
CrillZ
Quick question with 225/35/19 in the front and 255/35/19 in the rear, will i have issues with the VDC???
Old Jun 2, 2010 | 09:43 AM
  #9657
ATX350's Avatar
ATX350
Hey guys, Royal_T and I had a rig shoot over the weekend with Eddie and his sexy ZR. I need some damn breaks!
And a good pic of Eddie's ZR:
Old Jun 2, 2010 | 10:04 AM
  #9658
litoflow's Avatar
litoflow
^nice!! Triple E's
Old Jun 2, 2010 | 10:10 AM
  #9659
z33allme's Avatar
z33allme
Good job Eric! I am still kicking myself for not being able to make the shoot..
Old Jun 2, 2010 | 11:00 AM
  #9660
lixam's Avatar
lixam
how is this at all related to aggressive wheels and stretched tires....welcome Reply to Thread ??????????
