wheel specs please, just picked up a 04 z need wheel ideas.
Bro not to be a d!ck, but theres a million different ways to do it. Its all on how crazy you wanna go how much you wanna pull fenders etc. Take some time and flip thru this thread theres plenty of good information to educate yourself with.
i.e can be as simple as going 9.5/10.5 +0-? to some crazy shizz like 11/12 -23 its all up to you
Quick question guys, Getting ready to order some Weds, 18x10.5 +12 all around. Going to run spacers in the rear for sure but wondering which tire size to choose for the fronts.. Definatly running a 265/35 rear, but cant decide if I should do a 245/40 front or 235/40. Any suggestions?
I would go with 225/40 just in case you wanna run a spacer in front so you won't have rubbing issues...IMO
Im kinda thinking I wanna do a 255/35 now for some reason.. I was lurking earlier n saw a similar setup, 265/35 all around and I think just 1 step down in the front will be perfect. I gotta got get a bunch of different tires and play around with it I guess..
Believe me i know about wheel fitment, i know what it takes, i have the tools, ive done it numerous times on other cars. i was the first to pull off a 10" wide on a ef chassis. i just wanted his specs to go off of because i like how it sits. Simple as that.
you must be saying that to justify being a troll yourself. join date of 08 and 651 posts..
really flipped that around there and wounded me with that one.
thanks hannah montana for another pointless post.
well then if not a troll post you made maybe you need "your baby can read"
not wanting to argue was just stating an observation.
goodbye
pretty sure his specs are 19x10 -8ish... or maybe -11. and 19x11 -23 out back
19x10 0 19x11 0 will set you perfect homie with minimal fender work. But theres so many z's now that rock similar setups its getting boring.
i was at 18x10 -25 and 18x11 -17 but with major pull/roll.
Need some input, I've decided to run 235/40 on my 18x10.5 +12 fronts, not sure if I should go with a 235/40 rears or 265/35.. Rears are gonna be 18x10.5 -8
