Aggressive Wheels and Stretched Tires....Welcome
god. these cars come to life when they are set on the ground with proper fitment. its the way the designers invisioned the body to sit when in the design stage. along the line the car gets raised for commuting purposes and loses the wow factor.
well i check this thread everyday basically...but i dont fit the requirements, but im trying. well i put some spacers on my rear and i need to get my fenders rolled, i could pay to get em done but id rather keep that $ in my pocket. so any of you guys that have done DIY fender rolls and have had success and would like to share please pm me and teach me your ways.
thanks
thanks
^^if you look closely im missing the rear wheels waiting on tires. Pretty much im running my old set up in the rears but they tuck in a lot compared to before so if i decided to keep the old set up im probably going to buy a 20mm for them to when i use them.
Offsets right on that pic are F18x10-20 and R19x11-16 but rears will be replaced by the end of the week with 18x12-5...
Here you go... a teaser i am posting till the new tires come for the rears...
Fog loves fogging me! lol..winter project to fix the damn headlights...
Function Vs Form.. me and my boy playing around with our cars. My HellaFlush Z and his turbonetics G35 dyno at 450hp. I was very impressed to see my Z keeping up with the G until i hit the end of 4th gear shifting into 5th but i need a tune up pretty bad and my tires are bold lol..enjoy!
<object width="224" height="400" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/476070065971" /><embed src="http://www.facebook.com/v/476070065971" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="224" height="400"></embed></object>
<object width="224" height="400" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/476068975971" /><embed src="http://www.facebook.com/v/476068975971" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="224" height="400"></embed></object>
And the lower ring will give you about 3/16 of an inch while the upper ring will give a little over 1/4 inch. I took the upper one out for my current height
you might want to check if both your front springs are pre-loaded evenly. I had the same issue until I adjusted the spring pre-load to be even on both sides up front.
i tried searching but couldn't find any info on it so im hoping you stretch/poke/flush gurus can help me out here.
on a square 18x10 (+10F and +0 in the rear)setup...would you guys recommend running a 235/40 all around? or would i have vdc issues? if that isn't the right size to run...what would you guys recommend?
thanks in advance!
thanks in advance!
The car is not finished but I thought I would give you guys some teasers. The specs are going to sound pretty weak as I am running one of the largest bbk's on the market so here it is:
20 x 10 +15 bbk disk on 255's
20 x 12 +0 bbk disk on 305's
im tellin ya ... the 370z can have really **** fitment....this is a 12 0...withe plenty of room for more aggressive fitment...i know of a couple txans comin out with some fitted 370s
