Aggressive Wheels and Stretched Tires....Welcome
Old Oct 20, 2010 | 10:35 PM
  #12161
KTran's Avatar
KTran
Originally Posted by tribal_visionz
So, what are the pro and con's of using toe bolt kits over toe arms, vice versa.
Originally Posted by Max-G
the toe arms allow more adjustability. those spring buckets weigh a bit more than the toe arms, so you get rid of some unsprung weight.
yes, also, its not as goofy looking if you are running true c/o's, and the spherical bearing heim joints are more solid then the stock rubber bushing
Originally Posted by theianmcdougall
toe arm only adjusts a couple more degrees than stock
toe bolt kit's/midlinks- way more adjustablity and are really good if you wanna be super low and track your car too for good alignment specs
i think you got that backwards
toe arms - more adjustibility
toe bolts - less adjustibility
Old Oct 20, 2010 | 10:45 PM
  #12162
Max-G's Avatar
Max-G
lowered it another 3/8" today after replacing a torn cv boot. fun!
casualty of being low
lolpipe
carnage
result
i need real non-phone pictures :/
Old Oct 20, 2010 | 10:57 PM
  #12163
JDMStanced's Avatar
JDMStanced
Nothing can stop you from going lower huh lol
i wonder how the HFCs look like
Old Oct 21, 2010 | 05:30 AM
  #12164
350Z_Al's Avatar
350Z_Al
Originally Posted by htownimports
More pics from the front prease!
Old Oct 21, 2010 | 07:21 AM
  #12165
tribal_visionz's Avatar
tribal_visionz
Wow 350z_Boi, I'm getting excited for you! That's car of yours is looking so fresh, I can't stop looking at it. Haha
Old Oct 21, 2010 | 07:59 AM
  #12166
theianmcdougall's Avatar
theianmcdougall
yea i got em backwards
but im pretty sure midlink is the name of the arm with the bucket that holds the springs
man i wish i true coilovers so i could change em
Old Oct 21, 2010 | 09:47 AM
  #12167
350z_Boi's Avatar
350z_Boi
lol thanks man. I'm planning to go maybe a inch or half inch lower. Haha
Old Oct 21, 2010 | 12:38 PM
  #12168
fatboy.yoshi's Avatar
fatboy.yoshi
Originally Posted by -miltdoggie-
i wanna see what ur doing with that solara out back...
Old Oct 21, 2010 | 01:08 PM
  #12169
litoflow's Avatar
litoflow
Lol u did get it backwards. U should have gone true coils bro. Get rid of that fugly bucket.
Old Oct 21, 2010 | 07:53 PM
  #12170
tribal_visionz
So, Example: What if you're running the toe bolt kit on a true coilover setup, and you want to run a toe arm in the future? Is this no longer possible, after you already drilled out the subframe to fit the toe bolt kit. After installing the toe arm, won't the toe arm slowly move..later moving your toe out of spec.
Old Oct 21, 2010 | 08:31 PM
  #12171
-miltdoggie-'s Avatar
-miltdoggie-
Originally Posted by 350z_Boi
^^ SICKNESS Milt!!!
Thanks doggie, same to you!! That Z is looking very awesome!!!
Originally Posted by AVmagneticZ
+12r +9f 3mm spacer in front. 9.5f 10.5 rear.
245/35/19f 275/35/19r
Very clean to you sir!! ^^
Originally Posted by hatchboi
Looks sick milt! More pictures!
Once I clean it up and put the lip back on, it has been raining out here.
haha, that one is top secret!!!
It is possible, that logic does not apply.. You just lock in the toe bolt just like you would on the bucket..
YUM!!
This is the camber I am running... my toe is slightly off but I'll readjust tomorrow...
  #12172
ComeBack's Avatar
ComeBack
Hey did anyone remove their front fender lining or slightly roll their front fenders more?
Old Oct 21, 2010 | 08:55 PM
  #12173
Max-G's Avatar
Max-G
i removed the rear section. but left the front section committed suicide when i murdered an inner clipping point marker . you can definitely make the front half work with a little trimming and some zip-ties. definitely gotta roll your fenders if you're trying to be low/flush. that's a given...
anyone know how i could get my hands on some stanceworks coilovers?
Old Oct 21, 2010 | 09:04 PM
  #12174
ComeBack's Avatar
ComeBack
Well because I just put my coils on and the front tires were rubbing on the screws for the fender lining. So I was going to take it out and then maybe see if the fronts could be rolled a little. I just saw that your in davis & Sonoma i'm Sac and Santa Rosa lol.
Old Oct 21, 2010 | 09:09 PM
  #12175
KingBaby's Avatar
KingBaby
Hardest Setting
I removed my liner the back half and trim the pinch weld that's in the wheel well...works just fine...
only thing is when it rains the door jams will get dirtier than normal...
Old Oct 21, 2010 | 09:37 PM
  #12176
ComeBack's Avatar
ComeBack
Thanks looks like tomorrow the fronts are going a little lower and the lining is getting pulled out.
Old Oct 21, 2010 | 10:05 PM
  #12177
Max-G's Avatar
Max-G
haha you're domain encompasses mine! i pulled the screws out and rolled the fender with the front section of the liner in there so it kinda pinched it in place and then zip-tied it in a couple places.
Old Oct 22, 2010 | 12:36 AM
  #12178
350z_Boi's Avatar
350z_Boi
THmotorsports or AutoR&D but I went threw AutoR&D and got it in a week.
Old Oct 22, 2010 | 12:47 AM
  #12179
johzp's Avatar
johzp
If you were in socal I would hit you up for a shoot! haha love the 7 series wheels.
Milt hit me up soon haha car looks sick.
The guy with the vertex kit, can i see full body shots please!!!
AVmagneticZ: I wish my car looked like yours, very clean and nothing too crazy. Love it!
350z_Boi: I love it, i wish you were in socal so i can check out the ride in person.
Im embarrassed to show my car in here anymore, you guys are doing it big!
Old Oct 22, 2010 | 12:50 AM
  #12180
Max-G's Avatar
Max-G
these
not these
