Aggressive Wheels and Stretched Tires....Welcome
Old Nov 23, 2010 | 09:12 AM
  #12721
Max-G's Avatar
Max-G
Originally Posted by NY350zG
Nice Max G... seen your car on slammed society also... how was the event?
thanks. it was fun and chill since there weren't a ton of random people walking around.
favorite picture of the day
Old Nov 23, 2010 | 09:35 AM
  #12722
cheanyoung's Avatar
cheanyoung
Originally Posted by litoflow
I could try fitting them. I put a 20mm on my z making them 18x12-25 and i still had space to go. Its a close call though and crazy camber but i would give it a try if i didn't have others things in the work. Looking at it from my rear side. The fronts i do not know. Lol
I believe they only make them in 19s and they would be more difficult to run than 18s in that offset. just like running 20s are more difficult to run than 19s. I give spoolin and hatchboi major props for running negative negative negative wide 20s.
here is mine with a major pull fitting 19x13 -18 under the quarters. could possibly squeeze 5-10mm more depending on camber setting...
Old Nov 23, 2010 | 09:38 AM
  #12723
   's Avatar
I have to say the BMW 7 series looks really good on the z, damn!
Old Nov 23, 2010 | 09:39 AM
  #12724
stinky350z's Avatar
stinky350z
thats sick bro ^
Old Nov 23, 2010 | 09:41 AM
  #12725
350z_Boi's Avatar
350z_Boi
Sick cheanyoung!!!
Old Nov 23, 2010 | 10:25 AM
  #12726
spoolngst's Avatar
spoolngst
chean is right 18s will have alot more clearance due to diameter wise than 19s, just as 20s are harder to fit than 19s in the same specs.
Here some test shot of my spaced out 20x11 -42 (equivalent to 13s -20 which will be the range of my next setup but in 19s) just to give you an idea of what you will be dealing with if you want to attempt those Leons with stock quarters. Chean and my quater panel are flare and pull about the same amount.
Old Nov 23, 2010 | 11:01 AM
  #12727
litoflow's Avatar
litoflow
I respect ur opinion bro but i can definitely put a 35mm spacer to my 19x11-16 and still have space. I was super tucking them when i put them for couple days before the new set came by! And yeah it would b a crazy fit, but i preffer running no camber.
Old Nov 23, 2010 | 11:17 AM
  #12728
350z_Boi's Avatar
350z_Boi
damn that's sick spoolngt. You had to pull and flare it out a lot. Did you test drive it yet? How's the ride btw? Damn I'm looking into them ordens right now. But it would be crazy to pull off 19x12 -69
Old Nov 23, 2010 | 11:39 AM
  #12729
spoolngst's Avatar
spoolngst
i flare and pull about and inch but i was not able to drive cause i did not have a toe arm to correct the toe properly. I had to rig a lower toe/mid link to keep the toe in place while adjusting the camber but by the look of it i will need to run smaller tire to clear the quarter/bumper tab location with the 20s.
Old Nov 23, 2010 | 12:01 PM
  #12730
350z_Boi's Avatar
350z_Boi
Looks smooth how you flared it an inch more. You running camber kits or it's just stock camber and toe arms? Looking fresh btw.
Old Nov 23, 2010 | 12:03 PM
  #12731
starve's Avatar
starve
Pics, or it didn't happen. I'd love to see this 19x11 -51 offset on a Z.
Old Nov 23, 2010 | 12:34 PM
  #12732
litoflow's Avatar
litoflow
^^Sure ill do it up when i get back Home! I guess i should take a better pic of my fenders.
Old Nov 23, 2010 | 03:26 PM
  #12733
Royal_T's Avatar
Royal_T
Okay a tease before I post them up sometime tomorrow..
Old Nov 23, 2010 | 04:04 PM
  #12734
VQpoweredZ's Avatar
VQpoweredZ
This is what I like to see new pics!, Love the black Z on the BMW rims, Chean looking real nice man.
Royal the pic you just posted isn't working for me man, just letting you know, all I see is a blue question mark for some reason.
Old Nov 23, 2010 | 04:13 PM
  #12735
vex008's Avatar
vex008
pic not working for me either....
or did you post/delete
royal thats just mean man
lol
Old Nov 23, 2010 | 04:29 PM
  #12736
Max-G's Avatar
Max-G
personally, i think the sizes you have now are ****en perfect. i'm all for pushing the offset game, but it reaches a point where it becomes silly. anyone can bend the **** out of their fenders and at a ton of camber to fit some silly offset wheels. reaching a balance of aggressive size and offset with functionality is what makes an awesome car to me... or someone needs to start making reasonably priced rear over fenders for z's. then 20x15 -72 would be ok
Old Nov 23, 2010 | 04:48 PM
  #12737
Murfdizzle21's Avatar
Murfdizzle21
found this vid of johns Z, think he made it.
http://vimeo.com/16355254
Old Nov 23, 2010 | 05:27 PM
  #12738
spoolngst's Avatar
spoolngst
used a fender roller and im using spc camber arm and stock lower toe arm, but the camber is just alittle bit more than stock. Here are some pic of the roll/flare fender to give you and idea but try at your own risk
Old Nov 23, 2010 | 05:30 PM
  #12739
z33allme's Avatar
z33allme
Who is first?
Old Nov 23, 2010 | 06:08 PM
  #12740
Royal_T's Avatar
Royal_T
Okay sorry boys lets try this again...
