Aggressive Wheels and Stretched Tires....Welcome
Old Apr 18, 2011 | 01:50 PM
  #15401
SuperBlack350z's Avatar
SuperBlack350z
Originally Posted by lixam
i got stock camber arms all around and im like -3.5 ish up front...
is the front stock camber adjustable?
nope. only the front toe is adjustable.
Old Apr 18, 2011 | 03:04 PM
  #15402
Nemo7's Avatar
Nemo7
Originally Posted by phiooz
Here's some shots of my car Jake took for WFSU.NET
What are the specs on these?
Old Apr 18, 2011 | 03:54 PM
  #15403
Royal_T's Avatar
Royal_T
^^^^18×9.5 (-18) // 18×11.5 (-23) 215/40 & 255/40
Old Apr 18, 2011 | 05:06 PM
  #15404
mikex228's Avatar
mikex228
what lip is that ? i know/think its nismo..jus wondering if its rep or authentic
Old Apr 18, 2011 | 07:21 PM
  #15405
theianmcdougall's Avatar
theianmcdougall
makes me miss my VSKF's
woulda kept em if they fit a little better on the Z
throwback
Old Apr 19, 2011 | 08:37 AM
  #15406
RCFC89's Avatar
RCFC89
Originally Posted by nipponpower
post em up....
airrunner suspension
3piece meisters my favorite
Old Apr 19, 2011 | 03:22 PM
  #15407
on3_Lo35's Avatar
on3_Lo35
photos by Ryan Norris
my homie's GS
my other homie's HKS Supercharged IS350
my G35
my boy Smitty's M45
Old Apr 19, 2011 | 04:01 PM
  #15408
Highway Riding's Avatar
Highway Riding
Holy GS! Now that is WTF is up!
Old Apr 19, 2011 | 05:01 PM
  #15409
rps13drift's Avatar
rps13drift
Default help please
I need some serious tire help from the big dogs! I have been trying for the past few weeks to get a tire to stretch and bead on the rear wheels of my new set up with no luck at all My Wheel specs are 18x12 -13. I first went big and tried a 245/40/18 with no luck. I also had a set of 265/35/18 laying around and decided to try them. Again no luck multiple tries using every method in the book! Either bombs/cheeter tank/bike tubes/straps/etc... Im all out of ideas. Also When I do the either or cheeter it seems to work then all the sudden the tires bead just pops off the wheel. The front tires went on no problem 18x10 +12 235/40/18. Its been really depressing and I almost actually sold them because of this.
So if any of you guys have any other tips or tricks I havent mentioned please let me know! I would truely appreciate it.
Wheels
I-phone videos of failed attemps
Old Apr 19, 2011 | 05:15 PM
  #15410
350z_Boi's Avatar
350z_Boi
You could fit 225/40 on the front and 265/35 for the rears are good. Maybe you need to go with a different brand tires. Try them nexens, generals, khumos
Old Apr 19, 2011 | 05:16 PM
  #15411
350sx23's Avatar
350sx23
Maf cleaner(or w/e you have) + flame + air pump at the ready= enjoy.
Old Apr 19, 2011 | 05:21 PM
  #15412
Johnnyone's Avatar
Johnnyone
Got a lil work to do.
Old Apr 19, 2011 | 05:24 PM
  #15413
rps13drift's Avatar
rps13drift
Dang! I totaly forgot to add that to my first post. Both the cheeter and the fire method were tried with air line on the wheel with no valve stem.
Old Apr 19, 2011 | 05:30 PM
  #15414
KingBaby's Avatar
KingBaby
Hardest Setting
Seems alot of folks are jumping in to this deep unforgiving pool...
The above is gonna take alot of work to work!
Old Apr 19, 2011 | 05:32 PM
  #15415
Royal_T's Avatar
Royal_T
rps13drift,,
What tire brand are they? That could be your main reason.. also a 245/40 on that 12" will not work..
265/35 will def work... again it could be your tire selection, if they are run flats they will never fit.. trust me cause I tried some run flats for drifting and the tire blew and broke my buddies knee..
Old Apr 19, 2011 | 05:33 PM
  #15416
Royal_T's Avatar
Royal_T
Johnny, that will fit no prb, just a littler or on the fenders and you should be good. when you place the car on the ground it will camber in more so you should be striaght..
  #15417
Max-G's Avatar
Max-G
i wish someone would build a z like this. tucking looks sooooo much better than attempting to fit stupidly low offset wheels that end up poking like a lowrider.
Old Apr 19, 2011 | 05:38 PM
  #15418
rps13drift's Avatar
rps13drift
Thanks for the help Royal T! The 245's were dunlups and the 265's are Nexans
My last idea I have is to try two cheeters at the same time with an air line pumping! If that fails im screwed!
Old Apr 19, 2011 | 05:45 PM
  #15419
rps13drift's Avatar
rps13drift
I Like the tucked look more on 240's than the Z. My s14's sitting tucked right now
Old Apr 19, 2011 | 06:15 PM
  #15420
Johnnyone's Avatar
Johnnyone
Thxs Royal.
Anyone want to guess the size, the prop should help.
