Aggressive Wheels and Stretched Tires....Welcome
Old Apr 19, 2011 | 06:36 PM
  #15421
SuperBlack350z's Avatar
SuperBlack350z
Originally Posted by rps13drift
I need some serious tire help from the big dogs! I have been trying for the past few weeks to get a tire to stretch and bead on the rear wheels of my new set up with no luck at all My Wheel specs are 18x12 -13. I first went big and tried a 245/40/18 with no luck. I also had a set of 265/35/18 laying around and decided to try them. Again no luck multiple tries using every method in the book! Either bombs/cheeter tank/bike tubes/straps/etc... Im all out of ideas. Also When I do the either or cheeter it seems to work then all the sudden the tires bead just pops off the wheel. The front tires went on no problem 18x10 +12 235/40/18. Its been really depressing and I almost actually sold them because of this.
So if any of you guys have any other tips or tricks I havent mentioned please let me know! I would truely appreciate it.
i'm not trying to be a know it all but i do have experience on stretching tires at my previous work place. i've done plenty of all sizes. your problem is that after you shoot the cheetah, you need something in the valve to keep pressing air in. in your video, it's not just going ot seat it self by shooting air in it. you need an air shooting in your valve stem at a constant then shoot the cheetah.
It would be a lot easier if you had a tire machine where you can lift the tire up a bit before shooting the cheetah. Hope this helps a bit.
Old Apr 19, 2011 | 06:52 PM
  #15422
rps13drift's Avatar
rps13drift
Thanks for your input I am going to try it on a machine like you suggested. As for the air line it didnt help. I have tried it with the valves in and out with no difference. Same results as in the video. It always seems like its gonna work but just suddenly pops off. Its driving me nuts!
Old Apr 19, 2011 | 07:00 PM
  #15423
SuperBlack350z
you made sure there was no valve stem core in the valve stem correct? this is very important.
Old Apr 19, 2011 | 07:12 PM
  #15424
litoflow's Avatar
litoflow
rps13! Definitely look into what Superblack is telling you. Also make sure you have tires that can stretch easy. 265/35 is what i was on my last tires on my 18x12-5 so you should be good.
Old Apr 19, 2011 | 07:13 PM
  #15425
litoflow's Avatar
litoflow
[QUOTE=Max-G;9098137]i wish someone would build a z like this. tucking looks sooooo much better than attempting to fit stupidly low offset wheels that end up poking like a lowrider.
Why dont you show us the way Max-G? I bet it would look really good since they will not be poking like a lowrider...
Old Apr 19, 2011 | 07:57 PM
  #15426
350DAN's Avatar
350DAN
What superblack is saying is correct, one more trick that worked for me was airing up the tire (didnt require the cheetah) with the valve stem covered by the inside of the actual tire, just make sure holds the tire in the center of the barrel as its aired up. I ran 265/35 nexxens on my 18x12 -20 and it worked no problem.
Old Apr 19, 2011 | 08:25 PM
  #15427
Max-G's Avatar
Max-G
i kinda already did? although that was only when it was under load, not when it's hardparked. 8 months and i'll show the world how a parked z tucks rim without bags
Old Apr 19, 2011 | 09:04 PM
  #15428
vrbigdish's Avatar
vrbigdish
To rps13, i know everyone has already told you what to do, but when i did 265s on a 12 i did it on the tire machine. First i did the starting fluid trick and that helped alot with softening the sidewall(caught on fire a little then popped up) Next right after the flame goes out you put constant air like superblack said and cheetah. It should go, its worked with every set that i have stretched.
Old Apr 20, 2011 | 02:58 AM
  #15429
rps13drift's Avatar
rps13drift
Im going to try all of the suggestions mentioned this week! Thanks for all the input guys! Cant wait to post a pic of these pups on the Z
Old Apr 20, 2011 | 12:20 PM
  #15430
datsunHEAD's Avatar
datsunHEAD
Old Apr 20, 2011 | 12:48 PM
  #15431
vex008's Avatar
vex008
loving the nsx
Old Apr 20, 2011 | 04:21 PM
  #15432
D&G35's Avatar
D&G35
prob a repost but still luv this car..my friend is thinking of getting these wheels for his Aristo
Old Apr 20, 2011 | 04:29 PM
  #15433
Royal_T's Avatar
Royal_T
^^ yeah I love that car also.. The color combo is great..
Old Apr 20, 2011 | 06:52 PM
  #15434
zerostyle's Avatar
zerostyle
Rps13drift.... what you wana do is get the wheel on a tire changer. Get it clamped... use the cheetah and get it from under and already have an air line hooked up to the valve stem without a valve core and soon as that bead is sat get the air going through valve stem...then obviously put the valve core in.... if this still fails double cheetah it.
Old Apr 20, 2011 | 08:16 PM
  #15435
htownimports's Avatar
htownimports
what wheels are on the NSX? that thing looks great
Old Apr 20, 2011 | 08:23 PM
  #15436
zerostyle's Avatar
zerostyle
Looks like 360 forged concave series...forgot wheel name or number
Old Apr 20, 2011 | 08:58 PM
  #15437
Royal_T's Avatar
Royal_T
Okay boys and girls I am officially working with DPE Wheels and sitting up a Vendor thread on My350z.. Need some good pics of Z/Gs with DPE wheels to post up.. So if you could help me out please pm me pics or here..
Thanks guys
-edafe@dpe-wheels.com-
Old Apr 21, 2011 | 01:27 AM
  #15438
ATX350's Avatar
ATX350
^Yea buddy!
Old Apr 21, 2011 | 06:03 AM
  #15439
vex008's Avatar
vex008
Thanks guys
sorry couldn't resist
Old Apr 21, 2011 | 06:40 AM
  #15440
Threads's Avatar
A few pics of my car from our 5th-annual Louisiana Z/G Lakefront Meet.
BTW: Loving that Red NSX!
