Aggressive Wheels and Stretched Tires....Welcome
Old May 15, 2011 | 09:24 PM
  #15821
marques1's Avatar
marques1
Originally Posted by zlatan
10 front
15 rear
could i got with this to achieve a 0 offset or would this be to much?
front: 15mm
rear: 20mm
Old May 15, 2011 | 09:34 PM
  #15822
RurouniMidnight's Avatar
RurouniMidnight
Originally Posted by SuperBlack350z
you are lowering it the wrong way. don't lower from the perches, you turn the whole bottom coil mount.
Yes this is the way i did it, adjusted the preload then turned the whole shock assembly into the bottom mount.
Old May 15, 2011 | 09:41 PM
  #15823
SuperBlack350z's Avatar
SuperBlack350z
did you buy the coilovers used? something is wrong ..maybe a siezed coil. you can easily tuck the wheels with these coilovers.
Old May 15, 2011 | 10:05 PM
  #15824
Duckeee's Avatar
Duckeee
only thing i can think of if youre adjusting them correctly is incorrect spring lengths.
Old May 16, 2011 | 05:59 AM
  #15825
Johnnyone's Avatar
Johnnyone
I just put on true coils also and just to clarify, is this picture correct?
To max out the front and rear, I would turn the bottom portion up towards the spring till it didn’t turn anymore?
Old May 16, 2011 | 06:01 AM
  #15826
CORNELL's Avatar
CORNELL
front: 15mm
rear: 20mm
You should go with a 225 front and a 25mm spacer front 30mm rear
Old May 16, 2011 | 10:09 AM
  #15827
marques1's Avatar
marques1
THANKS BRO. I ended up going with a 225/35 tires up front with a 15mm spacer and out back I went with a 245/35 tire with a 25mm spacer. I'm hoping this will get me where I want to be.
Old May 16, 2011 | 01:36 PM
  #15828
Royal_T's Avatar
Royal_T
Okay the sale on my wheels fell through so they are now back on the market...
Asking $4,000
Here is link:https://my350z.com/forum/wheels-tire...h-17-6lbs.html
And here is a pic for ***** and giggles:
Old May 16, 2011 | 04:10 PM
  #15829
iLLest_Z's Avatar
iLLest_Z
Originally Posted by cheanyoung
looking good STAK!! i wonder how much additional work i will need to pull those off cleanly... over 30mm or so more aggressive, damn thats serious i wont even attempt that haha
progress pic:
what size are this...
Old May 16, 2011 | 05:09 PM
  #15830
zerostyle's Avatar
zerostyle
fixed...
Originally Posted by lixam
you guys are making me want 13 inches in the rear...
Old May 16, 2011 | 05:22 PM
  #15831
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
^^^ now that's funny.
Old May 16, 2011 | 06:11 PM
  #15832
cheanyoung's Avatar
cheanyoung
illest z, specs are 19x13 -18mm with a 305/30. gonna add a 3 or 5mm spacer for a little more poke...
Old May 16, 2011 | 07:01 PM
  #15833
DPE Wheels's Avatar
DPE Wheels
Vendor - Former Vendor
^^^ very nice
-Royal_T-
edafe@dpe-wheels.com
Old May 16, 2011 | 07:56 PM
  #15834
zerostyle's Avatar
zerostyle
Looks great and stupid camber... whens it gona be done?
Old May 16, 2011 | 11:26 PM
  #15835
Bruce Wayne's Avatar
Bruce Wayne
my subtle setup...
Old May 17, 2011 | 12:46 AM
  #15836
marques1's Avatar
marques1
very nice!!
Old May 17, 2011 | 05:22 AM
  #15837
Johnnyone's Avatar
Johnnyone
another step closer..
Old May 17, 2011 | 05:42 AM
  #15838
fatboy.yoshi's Avatar
fatboy.yoshi
jonny right idea, but the collars u r askin not to touch are the ones used to turn the whole shock assembly...turn that bottom one counterclockwise to raise and turn the top one clockwise to lower....of course make sure thems 2 collars are locked...
midnight wish i could see this in person and rectify...
Old May 17, 2011 | 05:50 AM
  #15839
Johnnyone's Avatar
Johnnyone
^ thxs you sir, glad someone confirmed this for me.
Coilover on - check
Toe bolt elogated and spc toe bolt on - check
UHP tires, 225/ 35 on 10 and 245/35 on a 11 - check
Currenly have a roller secured for this wknd but trying to get one sooner.
Old May 17, 2011 | 06:37 AM
  #15840
350Z_Al's Avatar
350Z_Al
A month and a half until my wheels are here and I can join the club
