Aggressive Wheels and Stretched Tires....Welcome
Old Jun 12, 2011 | 07:26 PM
  #16301
marques1's Avatar
marques1
Originally Posted by RurouniMidnight
This setup doesn't look aggressive at all from this pic. Do you have any side shot it looks as if the fender is tucking the whole tire. +2 also on the wheel design looking like crap.
Old Jun 12, 2011 | 07:55 PM
  #16302
RurouniMidnight's Avatar
RurouniMidnight
19x9 -15 225 40 19, 19x10 -10 245 35 19 your right nothing over the top aggressive trying to maintain nice balance i dont like running a uber amount of negative rear camber due to my car is used for drifting i use these in the streets and 18" TEs for track stuff.
Old Jun 12, 2011 | 09:55 PM
  #16303
Max-G's Avatar
Max-G
Originally Posted by Re-Amemiya
what do you use instead, hydro?
i've been using a slip-on extended lever that my buddy built for me, but i just snapped one of the cables so now i'm switching to hydro.
Old Jun 12, 2011 | 10:35 PM
  #16304
marques1's Avatar
marques1
must be the pic. your wheels look better in these pics. Wheel, setup like you said isn't that aggressive but decent.
Old Jun 13, 2011 | 09:24 AM
  #16305
datsunHEAD's Avatar
datsunHEAD
bump
Old Jun 13, 2011 | 11:52 AM
  #16306
lixam's Avatar
lixam
wheels on red Z look cheap chrome honestly..and design looks like something you see at the ghetto fab wheel/tire shop on the corner of the random street...
Old Jun 13, 2011 | 12:28 PM
  #16307
saberphx's Avatar
saberphx
Anyone know why my rear stance GR true coils wont go any lower?? It's pretty weird my rears are max down but my fronts have more room to go... is it possible they were ordered with less compressed springs for softer ride or something? Would compressing the spring about an inch get me lower? I've asked a few people and no one had to do anything like that to get the rear slammed...
Thanks in advance.
Old Jun 13, 2011 | 12:30 PM
  #16308
ZS14RR's Avatar
ZS14RR
Originally Posted by datsunHEAD
bump
lol
Old Jun 13, 2011 | 12:34 PM
  #16309
Max-G's Avatar
Max-G
Originally Posted by saberphx
[IMG][/IMG]
Thanks in advance.
have you removed collars? you can get about an inch lower with 2 removed.
Old Jun 13, 2011 | 03:01 PM
  #16310
Johnnyone's Avatar
Johnnyone
Thanks in advance.
I have true coils also and yea the fronts go lower than the rear. U can remove the collars like mentioned or u can get shorter springs from Stance.
I remember when I was searching for coils everyone was like stance will get u so low u can't drive it. Well u can get the front low but the rear not so much unless u ask for shorter springs.
Old Jun 13, 2011 | 05:47 PM
  #16311
Toby-22's Avatar
Toby-22
Thanks in advance.
you may be lowering it wrong. Are you twisting the base of the coilover up? something is obviously wrong bcs i can tuck rims without even removing the collars out back
Old Jun 13, 2011 | 06:32 PM
  #16312
Johnnyone's Avatar
Johnnyone
Here i am on stance true coils max out in the rear on 245/35 with around -4.6 degrees of camber.
And you can either twist the base of the coilover up or you can twist the top collar clockwise.
Old Jun 13, 2011 | 07:36 PM
  #16313
SuperBlack350z's Avatar
SuperBlack350z
something must be wrong with yours. mine can go down where i tuck rim.
Old Jun 13, 2011 | 07:45 PM
  #16314
SuperBlack350z
i can't locate a pic of my car but this was toby22's car with 245/35 as well with stance gr= true types. this was before he slammed it even more.
Old Jun 13, 2011 | 07:52 PM
  #16315
Toby-22's Avatar
Toby-22
huh? here is mine with about another 1" to go. This is with all the collars too
with only -3 camber and a bit higher than ^
Old Jun 13, 2011 | 08:03 PM
  #16316
KingBaby's Avatar
KingBaby
Hardest Setting
AWESOME
more of that purple car!!!!
Old Jun 13, 2011 | 08:07 PM
  #16317
SuperBlack350z
lol, that's not maxed out.
Old Jun 13, 2011 | 08:25 PM
  #16318
Johnnyone's Avatar
Johnnyone
It is without messing with the set preload correct?
If I move twist the top collar up I will mess with the spring rate correct?
Old Jun 13, 2011 | 08:41 PM
  #16319
Max-G's Avatar
Max-G
no, you can remove the two lower collars that aren't doing anything. no preload needed.
Old Jun 13, 2011 | 08:46 PM
  #16320
SuperBlack350z
yes, if you twist the top collars, you do mess with the preload but you dont even need to. no need to take off any collars unless you are trying to tuck three inches of rim
edit, by top collar, not including the two collars on the bottom for the lock. the one right underneath the spring..
