Aggressive Wheels and Stretched Tires....Welcome
Switch out to a 255/40 for the frot tires to even out the stretch, and please tell me your not driving your car around like that... If you are, please put stockies on till you can make the wheels fit. Unless your going for Mexifluch. Looks sexxy tho, I was gunna buy a set of those, Like three sets dropped in a month ALL around the same sizing.
You should be able to rock those fairly easily, prolly round -3.5/-4 camber out back and a good roll. Will def be goodlookin tho
ya im drivin my s14 around. . . this just sits in my drive way like that. . . and your right there was actually two sets in this size and color for sale at the same time on zilvia. . . Im actually pretty close to buying the second set so that i can run them on my s14 after i go wide body. . .
im planning on giving the rear a good pull so that I can run like a -3 max camber and im also thinking about changing the front tires to 245/40/18 and that should match the stretch too
Can't wait to be joining this group after a long awaited year and a half of saving/researching! I ordered my RPF1's 18x10.5 +15 all the way around, and my tires 245/40 all the way around as well. I only need one last bit of info. Should I run a +15 mm spacer in the rear for a +0 offset? Or a +20 mm spacer for a -5 offset? I don't want to have to pull my fenders, however they're already rolled. Which one should I run? And an estimate on camber (I already have rear camber arms)? Thanks a lot guys I'll post pics as soon as I get it all together.
^ THis is my buddies car with the same wheels specs and a 20 mm spacer. I would recommend 20 mm spacer. Not positive but i would say his camber is around -3.5.
Aggressive wheels going side ways FTW!
I don't really like posting side pics just yet cause bumper doesn't match the side skirts atm ( and they are from the same company lol) anyways here's two more and a pic with quick photoshop of how I intend to modify the bumper to flow better with the fenders and overall body lines. Wing and wiper are going to be removed soon and I'm thinking bout getting a Ti blast pipe made.
yo toby-22 what size tires are you using??
zach's car won best stance at stancewars.. i was really thinking about doing a color combo like this with my z/meisters, guess im going with green.
What are the tire specs on this! If it's anything close to 245/40 I'm going I'm going to order my 20 mm spacers asap.
My Z is sold guys. Ill be out the game for a minute running around in a lifted 4x4 but i got somethin planned for the end of year/winter time frame. Ill still be visiting the thread everyday though. Thanks guys!
guessing the wheels went with the car.
look forward to see you return in the winter.
although not belonging in this thread...interested to see how your 4x4 turns out as well.
