by how much the rears need more thicker spacers then front to have the wheels stick out then the front? same offset rims.
that sentence made zero sense....but i see what youre saying.
It depends so much on how low you are but id say typically 10mm more out back will have you sitting even. I personally have a 15mm difference but if it was 10 itd still look right.
hey guys I got my Zeal function X this week and got them installed today. Front is tucking rubber but rear is just not going low enough. I have crazy 16kg spring rate all around.
Now this is the two options I could come up with...
1- get 5in short spring to replace the current 7in one that came with the coilovers.
2- drop those 2 lock rings all the way down and get helper spring.
which way should I go? fenders are sitting right on top of the wheels atm.
thanks in advance !
Reason: uploaded picture
thanks in advance !
get the shorter spring and if that still doesnt work take out the perches to!! it is probably cause your springs are so ****n stiff
