Aggressive Wheels and Stretched Tires....Welcome
Old Aug 22, 2011 | 06:24 PM
  #17321
J rad's Avatar
J rad
Duckeee he has been featured, good job on the pictures Mario. Can't wait to cruise with you to wekfest.
Old Aug 22, 2011 | 06:41 PM
  #17322
AVmagneticZ's Avatar
AVmagneticZ
so im maxed out on my hypermaxIII coilovers and with my new setup it looks like the rear needs to come down a bit. what kinds of things do u guys do take out both of the collars on the spring? how much lower will that drop me? and for fronts all i can think of is tightening the preload on the spring will that do anything? or any other suggestions without having to change my coilovers.
Old Aug 22, 2011 | 08:47 PM
  #17323
bmxpert57's Avatar
bmxpert57
^cut 3/4" off the rubber rear spring perch. There's a how to on here. I did it and rear end sits perfect now
Old Aug 22, 2011 | 09:00 PM
  #17324
Duckeee's Avatar
Duckeee
i have them too and maxed out the rears today. if you remove both collars, the spring will have some freeplay (droop) until you lower the car off the jack. i wanted to play it safe so i only removed 1 collar on each side in the rear.
as for the fronts, they should go pretty low. adding preload will effectively lower it, but will have negative effects on handling. try removing the collars
you cant cut anything on hks hipermaxs. youre talking about the stock rubber mount
Old Aug 22, 2011 | 10:07 PM
  #17325
bmxpert57's Avatar
bmxpert57
Yes stock rubber mount
Old Aug 23, 2011 | 04:32 AM
  #17326
AVmagneticZ
How much lower approx did it go when you took one collar off the rear spring? The fronts i dont think u can remove any collars just tighten preload but my front is looking ok the rear will need adjusting. Im going to the shop after worl to get the tires and spacers put on so i will get them to do this as well. Any extra tips would be appreciated thanks guys
Old Aug 23, 2011 | 04:34 AM
  #17327
AVmagneticZ
512 z
Your Z looks really good
Old Aug 23, 2011 | 07:31 AM
  #17328
jduet's Avatar
jduet
Old Aug 23, 2011 | 08:38 AM
  #17329
GenX350z's Avatar
GenX350z
Default my feature on OPENCLUTCH.COM
http://www.openclutch.com/features/2...-money-can-buy
Old Aug 23, 2011 | 08:59 AM
  #17330
Duckeee's Avatar
Duckeee
from what it seems, however thick the collar is, is how much lower it'll go with it removed more or less.
hipermax's are not meant to lay frame. i mean, you can remove both collars, but the spring will droop until you lower the car off the jack like I said, which in return will affect handling.
removing 1 collar will yield you fair results, but dont have too high of an expectation.
Old Aug 23, 2011 | 09:59 AM
  #17331
RyebreadZ's Avatar
RyebreadZ
Smile
GenX more pics of current wheels please!
Old Aug 23, 2011 | 05:20 PM
  #17332
stinky350z's Avatar
stinky350z
looking sick mario ;D
Old Aug 23, 2011 | 05:43 PM
  #17333
512_Z's Avatar
512_Z
Thanks Ricardo good seeing you bro its been a while..
512 z
Thanks guys i appreacite it . J cant wait either its going to be alot of driving that weekend.. I was planning on not attending just beacuse of that drift event in houston but F**** it i will do both... LOL
Old Aug 23, 2011 | 05:58 PM
  #17334
gotboost36's Avatar
gotboost36
man i always wanted a ppw z but everytime i see your z i want to paint mine smb!!! you have one of the cleanest z's ever keep up the good work sir!!
Old Aug 23, 2011 | 08:47 PM
  #17335
z33allme's Avatar
z33allme
Thats good to hear Mario! We can meet up with you on are drive threw atx fri?
Old Aug 24, 2011 | 12:40 PM
  #17336
Waiz's Avatar
Waiz
OT posts removed, not the place for it.
Keep it in PM's or keep it to yourself.
Old Aug 24, 2011 | 04:46 PM
  #17337
350Z_Al's Avatar
350Z_Al
I test fit my rears on the front today and they fit real nice!... 19x11 -7 with a 245/35/19... Hmmmmm
Old Aug 24, 2011 | 05:02 PM
  #17338
Royal_T's Avatar
Royal_T
^^ Nice then i should be good with my 19x11 0 .. any pics
Old Aug 24, 2011 | 05:26 PM
  #17339
Silver350zed's Avatar
Silver350zed
Originally Posted by cyan
Some new pics since my move to rainy, sticky, shitty Florida:
I got 99 problems, but dial-up ain't one
Saw ur car by gamestop on Dale Mabry looked clean and I was wondering where it came from since I haven't seen it. Let me know if you need any thing nice *** ride man.
Old Aug 25, 2011 | 02:43 PM
  #17340
512_Z's Avatar
512_Z
Since no one post anything today LOL ill post this...
http://www.flickr.com/photos/shoryuuu/6053899620/
http://www.flickr.com/photos/65533272@N08/6071177035/
