Aggressive Wheels and Stretched Tires....Welcome
Old Oct 22, 2011 | 05:34 PM
  #18001
frankenstein!'s Avatar
frankenstein!
Originally Posted by low n slow
Because something in your setup was out-of-wack. You can sit here all day and say everything was perfect, but there was obviously a problem somewhere. Possibly you bought used spacers and were told the wrong size? You aren't providing much information aside from "this is the size, everything is perfect". Like Tehk and others have said, it doesn't add up, people have ran more aggressive setups with no problems on a slight pull.
I know that it doesn't add up, but I can't give anymore information except what I am 100% sure the specs were and how it fit together. I know what the alignment specs said for rear camber when it was on the rack and I adjusted the arms, I know the wheels were 10.5" 0 offset bought brand new and I know my spacers were 15mm bought new, referenced to the H&R site with part number.
I'm sure you all get sick of people asking the questions, but I'm not a complete moron when it comes to cars. I'm simply dumbfounded at the fact that it didn't fit.
Old Oct 22, 2011 | 06:11 PM
  #18002
cheanyoung's Avatar
cheanyoung
car been in any accidents to your knowledge?
Old Oct 22, 2011 | 06:15 PM
  #18003
frankenstein!
No accidents, bought the car new.
Old Oct 22, 2011 | 06:34 PM
  #18004
TehkMob's Avatar
TehkMob
What do you have for camber, traction and toe arms?
Old Oct 22, 2011 | 06:39 PM
  #18005
frankenstein!
SPC camber arms & Stance toe arms
Old Oct 22, 2011 | 06:50 PM
  #18006
Jacob350z's Avatar
Jacob350z
I ran 19x11-17 on rears with -4 camber and a good pull. Judging from the picture you put up you could use more pull.
No reason you should have issues fitting that size in the rear with that much camber.
Old Oct 22, 2011 | 07:22 PM
  #18007
DeeSan's Avatar
DeeSan
trolling? LOL maybe then sold you a fiero with 350z conversion
Old Oct 22, 2011 | 07:30 PM
  #18008
frankenstein!
Trolling? Oh ok, sorry for asking a legitimate question related to a legitimate issue directed to people who know way more about fitment than I do. Don't be an *******.
Old Oct 22, 2011 | 08:17 PM
  #18009
Johnnyone's Avatar
Johnnyone
^ i think it has to be your roll / pull. I bet the guys that can fit a more aggressive offset wheel and offset have a more aggressive roll and pull.
Old Oct 22, 2011 | 08:29 PM
  #18010
TehkMob's Avatar
TehkMob
No... We did a flat roll and fit 18x12 -4 with -2 camber, work equips.
Old Oct 22, 2011 | 08:38 PM
  #18011
frankenstein!
This is what I mean. It would help if anyone around me owned a G/Z and knew anything about wheel fitment, or if shops weren't clueless when you ask to pull fenders, or run negative camber. All my friends know are VW's/Audi's.
I appreciate the input from everyone, this is the first attempt for me in terms of going with semi-aggressive wheel fitment/cutting/pulling fenders. All the reading and research I do just didn't add up to my result.
Old Oct 22, 2011 | 09:07 PM
  #18012
Jacob350z's Avatar
Jacob350z
Get a roller and heat gun and do the pull yourself. Its not hard...
Old Oct 22, 2011 | 09:26 PM
  #18013
KingBaby's Avatar
KingBaby
Hardest Setting
Hey Frankenstien!
You seem like a smart enough cat! -7 is alot of camber and from that shitty picture it doesn't look like -7...
Can we get better pictures so that people can help you cause right now this is silly!
19x10.5 -15
Has been done a million times!
Old Oct 22, 2011 | 10:19 PM
  #18014
frankenstein!
Originally Posted by KingBaby
Hey Frankenstien!
19x10.5 -15
These are the only 2 pics I have...straight on from the rear and rolling from the side. In this pic the rears are -10 offset (smaller spacer).
Attached Thumbnails Aggressive Wheels and Stretched Tires....Welcome-303178_299062573442853_100000173371044_1440424_240509351_n.jpg   Aggressive Wheels and Stretched Tires....Welcome-316306_273213732699311_100000320580077_953006_2045967347_n.jpg
Old Oct 23, 2011 | 01:36 AM
  #18015
J rad's Avatar
J rad
Lone Star Bash coverage as promised..
512_z (blue z) and RurouniMidnight (red z) both made it out
http://vimeo.com/30971038
im the white z
Old Oct 23, 2011 | 07:52 AM
  #18016
TehkMob's Avatar
TehkMob
That's not near neg 7 camber..but either way something doesn't add up...
Old Oct 23, 2011 | 08:50 AM
  #18017
Waiz's Avatar
Waiz
I'm not sure why he's assuming a G35 will be able to run the same specs as a Z without issue.
It would have helped to say it was a G35 from the beginning, you can't run the same setup as a Z and expect the same results.
Old Oct 23, 2011 | 09:08 AM
  #18018
KingBaby's Avatar
KingBaby
Hardest Setting
I mean +15 not -15...
Yea something doesn't add up. I say find a shop that has done an alignment in specs then rip your car apart checking everything!
Bushings
Torque
Upper arms are on the right side
Then re install everything nd get another alignment. Sounds crazy but if it's never been in a wreck and everything seems to be in working order its the alignment!
That's where my money is
Old Oct 23, 2011 | 10:57 AM
  #18019
.eoJ's Avatar
.eoJ
<a href="http://s62.photobucket.com/albums/h108/socal91/?action=view&amp;current=6273625094_a6ef38070f_b.jpg" target="_blank"><img src="http://i62.photobucket.com/albums/h108/socal91/6273625094_a6ef38070f_b.jpg" border="0" alt="Photobucket"></a>
Old Oct 23, 2011 | 11:00 AM
  #18020
hpi10's Avatar
hpi10
Thank you. I have another question what is the size of dis orange 350z 18 or 19 zoll?? http://www.civic4g.com/index.php/for...=11243&p=98827
Thanks
