What should I do????!!!!
Old Dec 9, 2007 | 09:10 PM
pimpsahab's Avatar
pimpsahab
Default What should I do????!!!!
Right now i have 19's all around 8.5 in the front and 9.5 in the rear and running +25mm offset all around running 245's in the front and 275's in the rear on my 06 Z with springs..im getting coilovers and a rear camber kit installed and wanted to go as aggressive with the offset as possible!!! what are the most aggressive spacers i could do without rolling the fenders??? i was thinking of doing maybe 15mm spacers in rear and 10mm in front? i know the front would be ok but would the 15mm be too much since it would push it out to a 10mm offset? thanks in advance guys!
Old Dec 10, 2007 | 12:30 PM
pimpsahab's Avatar
pimpsahab
bump for suggestions!
Old Dec 10, 2007 | 12:59 PM
DustinZ33's Avatar
DustinZ33
Considering you can run a 19x10.5 +23 with 275/35, you shouldn't have any problems. You may need to leave some camber though since your not rolling your fenders.
http://www.1010tires.com/WheelOffsetCalculator.asp
