Rear tires rubbing with 10.5" +22 CE28n
I got the same setup 285/35/19 on a 19x10.5 +22 and i'm lowered on coilovers but I did roll the fenders. It's so low that it rubs on the inside of the wheel so I need spacers now.
Gotta love our sick offsets!
Here is a pic.
Gotta love our sick offsets!Here is a pic.
I have this same set up CE28N. But I am using coilovers. Before the fender roll (DIY very easy) I never rubbed. After roll I have a bit more room gonna put 5mm in rear.
Here is a quick pic I took (crapy) you really cant tell? But you get the idea I hope?
Read: the thickness of the tire's thread will also cause it to rub. The OP is running on Toyo T1R but i plan on getting the BFGoodrich g-force KDW's...any difference between the two?
z33allme: read your "fender roll" thread, so how did the paint held up?
Did you have to heat it first?
Sounds easy cause all you have to do is bend that perpendicular sheet of metal (in the rear) upward and pray to gawd the paint doesn't crack.
Sorry to hijack the thread....but
I thought buying the TE's from my friend then get some tires and i'm set, not....didn't know about the fender roll issue b/c of my wheel set up
255/35/19 +22 front & 285/35/19 +22 rear riding on stock suspension will rub OWNED
Thought about getting stance coilover and drop 1" front and 1.5" or more in the rear cause i want to acheive a aggressive....found out you'll need rear camber kit (more $$$) b/c of wear and tear issue on the inside of your tire OWNED
Not complaining but i just wanted to throw on the rims....lower my car and picture me rolling
dam'it
dam'it
Congrats! Car looks great.
I don't suppose you could take a pic of the whole car from side on. I just want to get an idea of fender gap in the rear.
And you said that is with a 1 inch drop?
Originally Posted by ReV2Red
Cutting will give you more issues, because then you've got bare metal that will need to be covered, and your left with a sharper edge.
a sharper edge, is there any other issues?
Originally Posted by Manu
Sorry but while on this topic, would there would be rubbing using the same rear wheels, 10.5 +22, with a 275 rear tire ?
Thanks
Thanks
Originally Posted by xxxlino
besides exposed metal, which can be covered with sealent
but search and they'll come. I'm sure there are plenty to choose from.
