tire size help
Old Jan 4, 2008 | 10:52 PM
mondi's Avatar
mondi
Default tire size help
not very good on the right tire size
i am buying rims 18x8.5 and 18x9.5
found a really good deal on 275/35/18 front and 295/35/18 rear
r they too wide of a set up? any handling problems
what would be the best set up with those rims and a 1.1 inch drop all around..thx
Old Jan 5, 2008 | 06:47 PM
terrasmak's Avatar
YOu need a minimun of a 9 inch front and 10 inch rear for those sizes.
Old Jan 5, 2008 | 07:51 PM
These are the same size as the NISMO wheels. What tires does NISMO recommend.
Old Jan 6, 2008 | 10:12 AM
Fooshe's Avatar
Fooshe
Careful! Those sizes won't work for those rims. Also, make sure the offset will work. Just because you know the width and circumfrance, does not mean they will fit with all tires. You need to know the offset, as well.
For 275/35/18 you need at least a 9 inch rim
For 295/35/18 you need at least a 10 inch rim.
Go to: http://www.carbibles.com/tyre_bible_pg2.html
Great site for tire and wheel questions. It will also calculate what your speedo will read with your new set up.
take your time and don't make a costly mistake.
Old Jan 6, 2008 | 12:11 PM
lowrider's Avatar
lowrider
245/40/18 - 275/40/18
Lou
Old Jan 6, 2008 | 02:59 PM
Spike100's Avatar
Spike100
^^ Lou, Those are the right tire sizes, but I think David was being sarcastic.
--Spike
Old Jan 6, 2008 | 05:30 PM
lowrider's Avatar
lowrider
^^ Oh
Lou
