help with wheels
Old Jan 7, 2008 | 05:31 PM
I do stuff's Avatar
I do stuff
Default help with wheels
edit: Well Im going with 19x8.5 up front et 35 and 19x9.5 in the rear with an et 40 wat will i need to do to get everything fitting write and what tire size do u recommend i was thinking 245/35 front and 275/35 rear
Im new to the 350z world so the whole tire size et thing to me it somewhat confusing
TIA
Old Jan 7, 2008 | 06:56 PM
Chad68's Avatar
Chad68
My wheels are 8.5 front 920 offset) rears are 10.5 (35 offset) I'm running excessive negative camber, so the rears should/would be more flush with the camber put back to where it should be.
Old Jan 8, 2008 | 05:23 AM
DustinZ33's Avatar
DustinZ33
Stay close to 22 for rear to have a flush fitment.
Old Jan 10, 2008 | 06:20 PM
I do stuff's Avatar
I do stuff
so i went wit 19x9.5 for the rear which would be better 25 or 20 et the wheels are 40 et so im guessing ill need spacers
Old Jan 10, 2008 | 06:31 PM
Motormouth's Avatar
Motormouth
I have 19x8.5 +22 and 19x10.5 +20
I would do:
+20 ALL AROUND with those sizes. with the camber in the front you will run lowered, it will look slightly tucked at +22 with a 8.5 rim on a 255/35 tire
tire size is also important when figuring this out, and will affect the stance alot, as tires can fill the gap from rim to fender... but if too small there will be a huge gap.
here is a picture of my rims as described (+22, +20 same sizes as you want):
Old Jan 10, 2008 | 08:02 PM
I do stuff's Avatar
I do stuff
edit to the wheels i decided to go with if all works right please any and all help would be appreciated
Old Jan 11, 2008 | 06:19 PM
I do stuff's Avatar
I do stuff
up?
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
