17x9.5 +20 with 275/40/17 front, should I stress it?
Old Jan 11, 2008 | 07:05 AM
nkohler's Avatar
nkohler
Default 17x9.5 +20 with 275/40/17 front, should I stress it?
I have a set of CCW classics in this fittament:
17x9.5F +20
17x10.5R +16
My car is dropped on cusco zero-2's and is pretty low, -2-2.5 deg camber up front (i do not have front camber arms).
I want to run 275/40/17 all around. The rear wheels already have a set of 275/40/17's on them, should I dismount one and put it on the front to test fit it just to be safe?
Just trying to save myself 40 or 50 bucks mounting/dismounting if people think that it will fit no problem.
Old Jan 11, 2008 | 07:38 AM
Alpha's Avatar
Alpha
I have 17x9 offset 27 up front and slammed. You shouldn't have any problems.
Old Jan 12, 2008 | 06:54 AM
nkohler's Avatar
nkohler
anyone else have thoughts?
Old Jan 12, 2008 | 07:02 AM
z-u-later's Avatar
z-u-later
I have an autocross setup with 275/40s all around mounted on 17x9 (+35mm offset) rims and they don't rub. I have 10mm spacers in front & 25mm in rear. And my Z (at lowest point) is about 3" off the ground.
Old Jan 12, 2008 | 09:38 PM
Endless Shock's Avatar
Endless Shock
It will fit just fine.
Old Jan 12, 2008 | 11:23 PM
terrasmak's Avatar
I run +22 with 255's on the front , or +27 with 275 . His setup is 8mm farther out than my setup i run on 255's , its going to be close , camber will be needed.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
