AXIS Wheels, Tire Suggestions... Please!!!!!
Old Jan 13, 2008 | 03:07 AM
SilverZed's Avatar
SilverZed
Default AXIS Wheels, Tire Suggestions... Please!!!!!
Hey guys,
I'm in the process of getting a set of AXIS Hiro Rims..
The specs are:
Front - 19" x 8.5"
Rear - 19 x 10.5"
I have VDC and TCS.
I'm dropped on as set of Tanabe NF210's(1.2" all round).
I'm thinking about going with the following tire sizes:
FRONT - 245 / 40 / 19
REAR - 275 / 35 / 19
Do you guys think this tire setup should be ok. I don't want to roll my fenders.
Or should I go with
FRONT - 245 / 35 /19
REAR - 285 / 35 /19
Any advise.... I'm more into looks, the car doesn't see the track or the D strip.
Thanks,
SilverZed
Old Jan 13, 2008 | 04:30 AM
Z_Monzter's Avatar
Z_Monzter
This is your best option for that setup:
REAR - 285 / 35 /19
However I would recommend 19x9.5 front instead with 255 / 35 /19 tire.
Old Jan 13, 2008 | 06:24 AM
Chad68's Avatar
Chad68
With the following setup, the rear tires would be 1/4" bigger diameter than your fronts. I don't know if that 1/4 larger diameter is enough to keep the slip light happy or not.
245/35/19
295/30/19
I have the same setup on mine except I have 305/30's on the rear. The 305's are a tad too wide for my taste, so i will be going to a 295/30 next, but I dont have to worry about any slip lights.
With the 245/35 and 295/30's on your 8.5 and 10.5 wheels, your sidewalls will be perfect front and rear, unless you're one of those types that likes to stretch the crap outta yer tires:-)
Old Jan 13, 2008 | 05:07 PM
SilverZed's Avatar
SilverZed
Thanks for the help guys....
I think I'm going to go with:
REAR - 285 / 35 /19
I haven't got the option to change the front rims to 9.5". I had to have the Hiro's custom ordered from the states because no body stock's these rims here in AUS anymore..
Old Jan 13, 2008 | 05:59 PM
Chad68's Avatar
Chad68
REAR - 285 / 35 /19
Not what I would do but hopefully you won't get a ton of understeer with that setup. Good luck
Old Jan 13, 2008 | 07:38 PM
Marino Z's Avatar
Marino Z
Know it all
275/35/19
there is big chance of being rubed in rear with 285/35 if your fender is nor rolled.
Old Jan 13, 2008 | 07:39 PM
Marino Z's Avatar
Marino Z
Know it all
and what are the offsets you trying to get?
Old Jan 14, 2008 | 10:30 AM
GARY_Z's Avatar
GARY_Z
Don't buy axis hiro..."
i know that's the early model Hiros.
but it's still risky to buy axis wheels imo
Old Jan 19, 2008 | 11:31 PM
SilverZed's Avatar
SilverZed
^ Thanks for the heads up... I saw those posts before. But I'm sure(Hope) they are have fixed their mistakes.
As for the order... I just got the wheels with:
Front - 245 - 35 - 19
Rear - 275 - 35 - 19
I haven't seen much difference in handling and the rear looks ok, I shouldn't need to roll my guards. I still have to get a alignment and I will post some pic's.
Thanks for all the help guys...
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
