will 19x10 +22 fit all around??
Old Jan 22, 2008 | 06:53 AM
yusoslo's Avatar
yusoslo
Default will 19x10 +22 fit all around??
Picking up a set of Enkie RPF1's and want to know if they will fit both front and rear. I want the flushest fitment possible.
thanks
Old Jan 22, 2008 | 06:56 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Old Jan 22, 2008 | 07:05 AM
DustinZ33's Avatar
DustinZ33
Yes but it depends what tire size your using. If you use the same size tires for the front and rear, you can rotate but you may want to get some spacers for the rear. I would say maybe a 255/35 or 265/35 all around with some 15mm spacers. May need to roll rear fenders as well.
Old Jan 22, 2008 | 07:18 AM
yusoslo's Avatar
yusoslo
I was thinking the same....a 10mm spacer for rear only and 265's all around.
Old Jan 22, 2008 | 09:10 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
265 oh a 10" wheel? Come on with the stretched look guys, it's ugly.
Old Jan 22, 2008 | 09:13 AM
Zridder19's Avatar
Zridder19
265 isnt a bad stretch by any means... i just did a 255 on a 9.5" and it looked good, barely any stretch
Old Jan 22, 2008 | 09:15 AM
JETPILOT's Avatar
JETPILOT
^ I agree.
I have a 295 on a 10" wheel....265??? That's ghey! You need a 9" wheel in the front with a 275/30/19, and a 10" wheel in the back with a 295/30/19.
The 10" front with tose offsets will rub with the camber in spec if you are lowered.
JET
Old Jan 22, 2008 | 09:18 AM
JETPILOT's Avatar
JETPILOT
^ STFU NOOB!
JET
Old Jan 22, 2008 | 09:27 AM
Zridder19's Avatar
Zridder19
Originally Posted by JETPILOT
^ STFU NOOB!
JET
Where have you been old man? Do you still even have a Z?
Old Jan 22, 2008 | 09:40 AM
DustinZ33's Avatar
DustinZ33
^ I agree.
JET
I dont think a 265 on a 10 will be a bad stretch either. Barely.
A 19x9.5 +17 with a 245/35 will fit. Why wouldn't a 19x10 +22 with a 255 or 265 not. The face of the 10 is only 1mm further out than the 9.5. With a 255 or 265 on it, with a little stretch, it will be possible. You just have to be careful of what tire brand you use as some are taller and wider than others.
Old Jan 22, 2008 | 11:08 AM
elcabron13's Avatar
elcabron13
I wanted the convave face of the RPF1 which I thought you only got when you have a 10" width.
Old Jan 22, 2008 | 12:50 PM
DustinZ33's Avatar
DustinZ33
the rpf1 isn't so concave. It has a small lip and a pretty much flat face. Just has a deep offset hub area.
Old Jan 22, 2008 | 01:15 PM
yusoslo's Avatar
yusoslo
there are 2 faces to them if you look closely. On is a very flat face and one does curve in to the hub. The curved face is only available on 10" models. Kinda like the FNO1RC wheels.
ie.
Old Jan 22, 2008 | 03:50 PM
prew's Avatar
prew
i was thinking of going with the same sizes. 265 is for 9-10.5" wheels per manufacturer specs btw.
Old Jan 22, 2008 | 05:20 PM
yusoslo's Avatar
yusoslo
i love how people run a 275 on a 10 or 10.5 all day long.
run a 265 on a 10 and its hella stretched! hah
Old Jan 22, 2008 | 06:01 PM
DustinZ33's Avatar
DustinZ33
I run 18x10.5 +15F and +0R with 265/35. Pics this weekend.
Old Jan 22, 2008 | 06:35 PM
Zridder19's Avatar
Zridder19
+1
Old Jan 22, 2008 | 06:54 PM
LanceKA-T's Avatar
LanceKA-T
The 17x9.5 +18's have the same concave face, but nobody runs 17's anyway
Old Jan 22, 2008 | 07:09 PM
ncdoc's Avatar
ncdoc
The GT model comes with a stock 265 on the rear 19x10 rim, you can hardly tell it is stretched at all.
ncdoc
Old Jan 22, 2008 | 07:17 PM
prew's Avatar
prew
yep same with the nismo.
