wheel spacer question
Old Jan 22, 2008 | 09:25 PM
350zist's Avatar
350zist
Default wheel spacer question
putting 10mm project kic spacers in the front but the stock studs are way too long...what should I fit the spacers properly?
Old Jan 23, 2008 | 03:03 AM
VIZAGE's Avatar
VIZAGE
You might get better results if you post in the wheel and tire section.
Old Jan 23, 2008 | 05:53 AM
DustinZ33's Avatar
DustinZ33
It depends if your wheels have space for the stud to fit into. Some wheels have the space, some don't. There is sort of an indention, a void, to allow the stock studs to fit behind the wheel.
Old Jan 24, 2008 | 07:05 PM
350zist's Avatar
350zist
no, the wheels dont have space thus me posting this question
Old Jan 24, 2008 | 07:16 PM
Sick Z's Avatar
Sick Z
Your only other option would be to get a different type of spacer, i.e. Ichibas. Sucks though cuz you have to install the longer studs.
Old Jan 24, 2008 | 07:53 PM
redlude97's Avatar
redlude97
use 10mm eibach spacers with extended replacement studs instead of the bolt on type of spacer
_koubie_
Sep 20, 2015 06:34 PM
torchkc
Sep 11, 2015 08:26 PM
