Conflicting info if this will rub or not.... could use some opinions
Old Jan 26, 2008 | 08:08 AM
jimmypuspounder's Avatar
jimmypuspounder
Default Conflicting info if this will rub or not.... could use some opinions
Hey guys, I have a 06 ppw enthusiast, im planning on sticking with the factory 18 wheels. But im looking to get a more aggressive stance.. Im planning on lowering on eibachs pro kit, but I cant decide if i should get 25 mm spacers all around or 20 mm. Ive searched and found guys that say 25 mm wont rub, and others that said it rubs... (im not going to roll my fenders). If someone could clear this conflicting info, it would be much appreciated.
Thx Mike
Old Jan 26, 2008 | 09:06 AM
Zivman's Avatar
Zivman
Thx Mike
you keeping stock tires as well? or going larger?
Old Jan 26, 2008 | 09:52 AM
jimmypuspounder
sticking with stock for now, not doing to any power upgrades so ill probably stick with the 225, 245's
Old Jan 26, 2008 | 10:12 AM
Zivman's Avatar
Zivman
OK, here are the specs on your current wheels/tires:
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
Based on that, you could definitely run a 25mm spacer up front and even a 30mm spacer in the rear without issue.
Running 25mm on all fours would bring you to a 18x8 +5 in the front which is the same as a 9" wheel with a +18... and an 18x8.5 +8 rear which would be the same as a 10.5" wheel with a +33.
The front at +5 is approaching agressive, but the rear at +8 isn't all that agressive. You could easily go to a 30mm spacer out back IMHO, and even go to a 40mm if you wanted to go agressive, but that might require a fender roll.
Old Jan 26, 2008 | 01:41 PM
z-u-later's Avatar
z-u-later
^+1 25mm front & 30mm rear on stock rims/tires --> no issues.
350Z_Al
Oct 29, 2020 07:44 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
