Will my muteki lugs work?
I just ordered a set of 25mm (R) and 20mm (F) spacers to go with my rays track wheels. I don't know if this matters but they are hubcentric and both have extended lugs... Will the muteki close ended lugs I just bought fit the studs on the spacer? I'm afraid the thread is going to be too long and with a close ended won't tightly secure the wheels. Thanks
i ran 25 mm spacers all around on track wheels
i had muteki short open ended lugs and worked just fine
close ended prolly would work too.
the studs werent sticking out of my open ended lugs
Thanks I wanted to keep it clean and didn't think I needed extended lugs. We'll see
You will be just fine, the spacer takes up the room that is added with the extended lugs. Personally i run open ended lugs so i can run any combo of spacer i want, some of my wheels i dont need spacers.
you'll be happy with the look
i got the ones off ebay. $78 shipped a pair with stubs built in already.
sellers name was optionselect i think
they change the look 100% times better
i would have went 25mm front and 30mm rear but only projects kics sells the 30mm with the studs prebuilt in them already.
