Filled with Nitrogen!
Old Feb 9, 2008 | 09:10 PM
_NIZMO_'s Avatar
_NIZMO_
Originally Posted by jarulez9
Im sorry but at the same psi as air Ive definately felt a difference during AutoX... maybe thats just me... opinions are like NIZMO!
Ill just close this thread now.
Old May 6, 2008 | 09:07 PM
phreaktor's Avatar
phreaktor
Design Engineer
Originally Posted by _NIZMO_
your and idiot. nitrogen vs air makes no diff in handling
Old May 6, 2008 | 09:16 PM
tware's Avatar
tware
Originally Posted by yusoslo
most are filled with bullsheit and hopes and dreams.
another thing I heard was it isnt supposed to eat at the tires as much...that what a mechanic told me but i never researched it.
I also filled mine with bullsheit, hopes and dreams. My handling was vastly improved.. But, my car runs on rainbows, so your mileage may vary.
Old May 7, 2008 | 02:37 PM
angelzhope720's Avatar
angelzhope720
I beg to differ. So my r compounds on my evo9 with nitrogen makes no diff in handling? So many idiots on this forum.
If any of you knew anything about racing you probably wouldn't make such immature comments about this guy's problem. Race cars use nitrogen in their tires. You want to know why? As tires heat up and cool down, tire pressures change dramatically and by using nitrogen in turn provide better handling.
Old May 7, 2008 | 02:42 PM
blasian's Avatar
blasian
Originally Posted by [B
jarulez[/B]9]Side note...
Having my TPMS sesnor act up everyday after 10 minutes of driving on the same wheel (just one wheel) saying my PSI is low and then it goes away saying my tire psi is back to normal all the time.. Do I just need to replace it?
Thanks!!
Seriously... screw the thread, I think the funniest thing is the OPs name
I filled my tires with Red Bull.
Old May 7, 2008 | 03:27 PM
terrasmak's Avatar
Actually knowing and setting your tire pressure will give you better handling , doesnt matter if you have air or nitrogen in your tires.
Old May 7, 2008 | 03:43 PM
redlude97's Avatar
redlude97
How is this different than air?
Old May 7, 2008 | 03:44 PM
tware's Avatar
tware
well.. the nitrogen bonds with the R compound and...
Old May 7, 2008 | 05:56 PM
Spike100's Avatar
Spike100
I am aware that my following comments expose me to ridicule, but I would like to offer my actual experience with “nitrogen-fills.”
I’ve been running my tires (summer performance tires and winter tires) with “nitrogen-fills” for about 3 years now. I really like the “nitrogen-fills.” I’m in Minnesota where we experience very wide variations in ambient temperatures and humidity. We see everything from arctic conditions to nearly-tropical temperatures and humidity.
The advantages I experience with “nitrogen-fills”:
  • When running nitrogen, I have more consistent tire pressures with little need to add “air.” When I ran “plain air,” I was constantly filling the tires to maintain correct pressure.
  • There is little or no condensation/moisture on the inner walls of my wheels when I fill with nitrogen. That is not the case when I used “plain air.” This is most evident during the winter months.
I have no idea if “nitrogen-fills” improve performance since I don’t track or drive aggressively to the point I could evaluate this difference.
My point is simply that for my setup and the way I drive and use the car, “nitrogen-fills” provides a significant difference.
--Spike
Old May 7, 2008 | 06:14 PM
Spork's Avatar
Spork
^^ Hello fellow Minnesotan.
My tires are filled with nitrogen, but I really tell no difference.
Old May 7, 2008 | 06:24 PM
Spike100's Avatar
Spike100
Not even more consistent pressures?
--Spike
Old May 7, 2008 | 06:30 PM
Mike Wazowski's Avatar
Mike Wazowski
I fill mine with methane gas. smells bad, but they sure do go, once they warm up.
Old May 7, 2008 | 06:38 PM
Spike100's Avatar
Spike100
Another point… 3 years ago when I swapped out my snow tires for new ones (and using “plain air”), there was visible condensation and moisture inside the wheel.
After the swap, and during the last 2 years, I ran the snows with “nitrogen-fills.” I swapped again this year, and there was no condensation or moisture. I’m guessing it was the “nitrogen-fills” that prevented a wet surface on the inside of the wheel.
I would think moisture inside your wheel is a bad thing, and “nitrogen-fills” seems to eliminate this.
--Spike
Old May 7, 2008 | 06:47 PM
06dieselZ's Avatar
06dieselZ
+1
I highly suggest using methane/propane mix to fill the tires
Old May 7, 2008 | 06:53 PM
Spike100's Avatar
Spike100
Originally Posted by 06dieselZ
+1
Larger molecule with less leakage through the tire walls?
--Spike
Old May 7, 2008 | 06:57 PM
tware's Avatar
tware
there is nothing to ridicule about your statements. THAT is exactly what the nitrogen fills are for, pressure consistency over temp changes. Everyone above is basically saying the only way he would feel a difference is that he was at the proper PSI (and wasnt before). No doubt there are advantages to it, but 35 psi = 35 psi as far as the car is concerned.
Old May 7, 2008 | 08:20 PM
chaparro78's Avatar
chaparro78
should use this kind of air
http://kalecoauto.com/index.php?main...products_id=45
Old May 7, 2008 | 09:43 PM
  #38
terrasmak's Avatar
--Spike
A cheap home solution for this is a $20 water seperator on your air compresser. Its the water that gets in the wheel that changes the pressure more with heat. The dryer the air the better.
Old May 7, 2008 | 11:46 PM
  #39
cbr900son's Avatar
cbr900son
I prefer liquid nitrogen.
Old May 8, 2008 | 12:06 AM
  #40
blasian's Avatar
blasian
I'm currently working on filling up a tank with my farts so I can put it in my tires. It may not be faster... but at least if I have a leak in my tires I'll be able to tell.
